Mega Dynamic Contrast Ratio delivers a mega experience. Make a difference with new Eco saving modes. Get comfortable with a wider viewing angle thanks to Magic Angle. Make an impression with the new slim and modern design monitor.
Style and functionality in one design
With its high-gloss black finish and clean lines, this monitor has a sophisticated and modern design that is sure to make an impression. -
Upscale your view with better quality
Magic Upscale technology enhances the image quality no matter what the original picture quality was. Magic Upscale prevents image degradation when scaling up and gives only the most brilliant and pristine colors and images. -
Experience real color with mega DCR
Mega Dynamic Contrast Ratio delivers enhanced levels of color and picture quality to your viewing experience with images that are real-to-life. Mega DCR's contrast ratio shows blacks at their absolute darkest and whites and colors at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. -
Less power consumption, conserve energy
Eco saving makes saving energy easy. The brightness of the monitor can be adjusted based on how much energy you want to save. And with the choice of three energy saving modes: 50%, 25% and power saving off, you can tailor your monitor use to meet your own personal needs. -
See it clearer with wider viewing angles
Enjoy the most comfortable viewing experience with Samsung's magic angle. This feature centers the image and eliminates distortion to provide amazing picture clarity whether standing, sitting, or even lying down.
- Samsung S24D300HL - SD300 Series - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Class
- Class A
- Energy Consumption per Year
- 29 kWh
- Power Consumption (On mode)
- 20 W
- Panel Type
- TN
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 700:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Voltage
- AC 120/230 V (50/60 Hz)
- Black lacquer
- 56.9 cm x 19.7 cm x 41.72 cm
- 3.55 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Display Type
- Energy Class
- Class A
- 29 kWh
- Diagonal Size
- 23.6"
- Panel Type
- TN
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- 700:1
- Colour Support
- Response Time
- 5 ms
- Backlight Technology
- LED backlight
- Power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale
- Black lacquer
- 56.9 cm x 19.7 cm x 41.72 cm - with stand
- 3.55 kg
- VGA , HDMI
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- Input Voltage
- 20 W
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.72 cm - weight: 3.55 kg , Without stand - width: 56.9 cm - depth: 5.39 cm - height: 34.21 cm - weight: 3.2 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
