Choose a Samsung Series 4 LED Business Monitor for maximised viewing and efficiency with minimal hassle. Purely professional, it's designed with a stylish narrow bezel to make the most of the screen and reduce distraction. To help you reduce business costs, it's also more energy-efficient, consuming just 0.1 watts of electricity when in standby mode. Ensuring you get the best and most comfortable viewpoint, your new monitor features simple height adjustment, too. You can even use the VESA Wall Mount to hang it securely and make the most of your space.
Experience minimal design and maximum effect
Maximize your monitor experience with the help of a chic narrow bezel, that helps reduce distraction when looking at the monitor and therefore increase the levels of concentration. The extra screen space also makes it easier to set up a dual monitor workstation, which also adds to work productivity. For those who just want a smart looking monitor, the narrow bezel adds a sophisticated look and feel to any desk. -
Help business with cost-cutting technology
Minimize your work costs with the help of the new DPMS 0.1W feature . It ensures that your Samsung Business monitor only consumes a maximum of 0.1 Watts while in standby mode. This amazingly low consumption is beneficial both financially and environmentally, and is simply unmatched by competitors. -
Maximize your space with easy wall mounting
Give your monitor the best possible positioning with the VESA Wall Mount. Easy to mount and install, it is convenient, safe and perfectly compatible with your monitor. You will always have a great viewing angle and will make the most of your space thanks to the monitor -
Upgrade to the next level with Mega Dynamic Contrast
Mega Dynamic Contrast Ratio delivers new levels of color and picture quality to your viewing experience with images that are real-to-life. A breathtaking Mega8 DCR contrast ratio shows blacks at their absolute darkest and pristine whites and other colors at their brightest. You will notice the crystal clear picture clarity. It is like explosions of colors that make other screens seem dull in comparison. Enjoy your multimedia content with the professionalism it deserves. -
Improve your work with HAS design
Find the perfect viewing experience with the help of Samsung's Height Adjustable Stand (HAS). It's simple controls allow for users to tailor their monitor height and angle to meet their exact eye level and therefore improve their productivity when working. It ensures that users are always benefitting from the best. -
Keep your work space as efficient as your monitor
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing it, the is ready to deliver an efficient and clean work space. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor.
- Samsung S24C450B - SC450 Series - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.27675 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 56.54 cm x 22.4 cm x 48.67 cm
- 5.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27675 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Power off timer, MagicTune, MagicRotation, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
- Matte black
- 56.54 cm x 22.4 cm x 48.67 cm - with stand
- 5.2 kg
- VGA , DVI-D
Mechanical
- Tilt Angle
- -3/+25
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by / Sleep
- 0.1 Watt
- Included Software
- Samsung MultiScreen
- Dimensions & Weight Details
- With stand - width: 56.54 cm - depth: 22.4 cm - height: 48.67 cm - weight: 5.2 kg , Without stand - width: 56.54 cm - depth: 5.67 cm - height: 33.32 cm - weight: 3.5 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80%
