The ME-C series features 1920 x 1080 Full HD resolution with 450 nits brightness and 5000:1 contrast ratio for sharp, detail-rich images and crisp, easily legible type. And the stylish 1.2" thin chassis helps simplify installation and makes it suitable for most locations.
The slim bezel design of the ME-C series ensures that nothing gets in the way of what's on screen. The result is messaging with maximum impact.
Edge-lit, ultra-slim HD LED display
The ME-C series features 1920 x 1080 Full HD resolution with 450 nits brightness and 5000:1 contrast ratio for sharp, detail-rich images and crisp, easily legible type. And the stylish 1.2" thin chassis helps simplify installation and makes it suitable for most locations. -
Narrow bezels
The slim bezel design of the ME-C series ensures that nothing gets in the way of what's on screen. The result is messaging with maximum impact. -
Integrated TV tuner
Provides the option of easily displaying broadcast TV. -
Lower TCO
LED technology consumes an average of 40% less power, for lower total cost of ownership. -
SMART signage platform compliant
This integrated, open-source platform provides a powerful streamlined solution that reduces TCO for digital signage deployments, providing savings in hardware, installation and operating costs.
- Samsung ME55C 55" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- 143 Watt
- Power Consumption (On mode)
- 78 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 114 kWh
- Dimensions (WxDxH) - without stand
- 124.8 cm x 2.99 cm x 72.24 cm
- 16.4 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A+
- 143 Watt
- 78 W
- 114 kWh
- Diagonal Class
- 55"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 124.8 cm
- 2.99 cm
- 72.24 cm
- 16.4 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Edge-lit LED
- Coating
- Super Clear
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 5000:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Lamp Error Detection, Smart Scheduling, MagicInfo Premium-S
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- 2 x HDMI input , Composite video / component video input , Audio line-in , DVI-D input , VGA input , Audio line-out , Serial input , Remote control , USB 2.0 , DisplayPort , Serial output
- Cables Included
- VGA cable
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years - on-site
- Width (Shipping)
- 136.9 cm
- Depth (Shipping)
- 19.9 cm
- Height (Shipping)
- 84.8 cm
- Weight (Shipping)
- 22 kg
