Choose the Samsung Galaxy Note 10.1 and discover the new way to set your creativity free. It's portable, yet offers multitasking like a PC thanks to its large 10.1-inch screen. Meanwhile, the intuitive and precise embedded S-Pen makes it so simple to take notes, draw, sketch and express yourself perfectly. With S-Note, your note-taking is full of rich possibilities which you can easily put together into a story. Shape Match even lets you visualise your ideas and turn them into quickly into graphs and other finished items you'll be proud to share.
Multiscreen Real multitasking on the portable 10.1" screen
Now, you can do 2 things at the same time. For example, what if you want to see an actor's profile while watching a movie you recently downloaded? Just use the “Multi screen" button and open the internet browser or the S Note. You don't need to stop the movie or the browser so that you surf web or make a note. If you want to copy the image? Just capture and drag it to the S Note opened right next to the web page. -
Embedded S Pen: Real Pen-like feeling for a natural writing experience
Precise versatile S Pen enables you to get a premium experience for note-taking, sketching, drawing, and other forms of creative expression. -
S Note: The easy-to-use creation tool
7 Templates to express life's every detail.Make your own story by selecting one of the S Note templates. S Note makes your note-taking and creation rich and neat. 7 templates: Note / Idea note / Meeting Note / Magazine / Diary / Recipe / Travel. -
Shape Match
Visualise your ideas better by turning squiggly shapes into neat organised figures. The Shape Match will automatically corrects the lines and shapes. -
Formula Match
Easily recognise complicated formulas to text and even find detailed and visual solutions.
- Samsung Galaxy Note 10.1 - tablet - Android 4.0 - 16 GB - 10.1" - 3G
- Product Type
- Tablet
- Operating System
- Android 4.0
- Display
- 10.1" TFT - 1280 x 800 - Multi-Touch
- Processor
- Cortex-A9 (Quad-Core)
- Processor Clock Speed
- 1.4 GHz
- Storage
- 16 GB
- RAM
- 2 GB
- Supported Flash Memory Cards
- microSD
- Cellular Technology
- 3G
- Cellular Protocols
- GSM, GPRS, EDGE, HSPA+
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 4.0
- Rear Camera
- 5 Megapixel
- Front Camera
- 1.9 Megapixel
- Navigation System
- A-GPS/GLONASS
- USB host
- 26.2 cm x 0.89 cm x 18 cm
- 600 g
- Grey
- Product Type
- Tablet
- Operating System
- Android 4.0
Display
- 10.1" TFT
- Resolution
- 1280 x 800
- Touchscreen
- Multi-Touch
- Processor
- Cortex-A9
- 1.4 GHz
- Number of Cores
- Quad-Core
- Storage
- 16 GB
- RAM
- 2 GB
- microSD
- Max Supported Capacity
- 64 GB
Communications
- 3G
- Band
- GSM 850/900/1800/1900 / UMTS 850/900/1900/2100
- Wi-Fi Direct
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Serial Port Profile (SPP), Generic Access Profile (GAP), Generic Object Exchange Profile (GOEP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), General Audio/Video Distribution Profile (GAVDP)
Rear Camera
- Sensor Resolution
- 5 Megapixel
- Camera Zoom
- 4x digital zoom
- Light Source
- LED light
Front Camera
- Sensor Resolution
- 1.9 Megapixel
Navigation System
- Receiver
- A-GPS/GLONASS
- Software Included
- Google Maps
Multimedia
- Supported Digital Audio Standards
- WAV, WMA, AAC, Ogg Vorbis, AMR, MP3, FLAC, AC-3, AAC +, eAAC+, MIDI
- Supported Digital Video Standards
- DivX, MPEG-4, AVI, WMV, MKV, H.264, VC-1, 3GP, ASF, FLV, H.263, VP8
- Audio
- Microphone, stereo speakers
Software
- Preloaded Software
- Clock, To Do List, Calculator, Worldtime, Calendar, E-mail, T-9 Keyboard, Scheduler, SMS, Alarm, instant messaging, vCard, vCalendar, S Planer, S Memo, Video Hub, S Note
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x headset , 1 x dock
- USB Host
- Technology
- Lithium Ion
- Capacity
- 7000 mAh
- Talk Time
- Up to 2000 min
- Standby Time
- Up to 1500 h
- Grey
- Sensors
- Accelerometer, ambient light sensor, digital compass, gyro sensor
- Included Accessories
- Power adapter, S Pen
- 26.2 cm
- 0.89 cm
- 18 cm
- 600 g
