Give your business communications the quality it deserves with an ultra bright LFD like the 550DX Series. It combines a high performance with durability to deliver a totally professional service. The DID panel and crystal clear picture ensure that your screen stands out amongst competitors. And for even greater impact, you can simply connect them to create a video wall. The 550DX also features the latest in connectivity with various ports and management software, which lets you minimise the time taken to complete maintenance and any software upgrades. Make your workload easier with an LFD like the 550DX.
Choose The Right View, Landscape Or Portrait
This Samsung LFD gives you the flexibility to display your image vertically or horizontally—whatever the situation calls for. With a pivot function that rotates the screen 90°degrees and the freedom to display presentations in portrait mode or advertisements in landscape mode, this makes for one versatile monitor. -
A Smart Sensor That Automatically Saves Energy
Stop worrying about the lighting conditions affecting your display. This Samsung LFD adjusts its brightness levels as ambient light changes so your images are always crystal-clear. And while it compensates for low-light and high-light environments, you'll save energy and stay eco-friendly. -
Save money, save space with built-in speakers
Maximise your impact with a great picture and crisp audio. Your message will be heard loud and clear with built-in speakers. You'll save money when you eliminate the cost of purchasing separate speakers, and you'll save valuable space as well. -
Enhanced connectivity without extra costs
Create a professional digital display without having to purchase any extras—like a distributor or external equipment. Samsung makes it easy with a display port that delivers enhanced connectivity and an improved display interface. With a simple adapter, you can connect your PC, monitor or TV using an HDMI or DVI cable that's more than twice as long as standard cables. Discover an easy, cost-effective way to create a powerful display. -
Set a schedule that's always on time
Keep your monitor running efficiently at all times. This Samsung LFD boasts a smart scheduling feature. The automatic power on/off function allows you to designate time, day, volume, input source and holiday dates. There's even a convenient on-screen display setting with up to 3 schedules including day and time.
- Samsung 400DX-3 40" LCD flat panel display - Full HD - for digital signage
- Product Type
- LCD flat panel display
- Diagonal Class
- 40"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite, HDMI
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- S-PVA
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- Voltage
- AC 120/230 V (50/60 Hz)
- 200 Watt
- Power Consumption Stand by
- 2 Watt
- 93.2 cm x 13 cm x 54.8 cm
- 17 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 200 Watt
- Diagonal Class
- 40"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- 93.2 cm
- 13 cm
- 54.8 cm
- 17 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3000:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 700 cd/m²
- Colour Gamut
- 72% (NTSC)
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.46125 x 0.46125mm
- Response Time
- 8 ms
- Max V-Sync Rate
- 85 Hz
- Max H-Sync Rate
- 81 kHz
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- DVI-D input , VGA / component video input , DisplayPort , Audio line-in , Composite video input , HDMI , Audio line-in , 2 x serial
- Cables Included
- VGA cable
- CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, NEMKO, NOM, PCBC, SASO, SIQ, FCC Part 15 B, CCC, FCC Part 15, PSB, IRAM, KCC
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 5.0
- Power Device
- Power supply - internal
- Input Voltage
- 2 Watt
- Width (Shipping)
- 104 cm
- Depth (Shipping)
- 29.5 cm
- Height (Shipping)
- 66.8 cm
- Weight (Shipping)
- 22 kg
