Samsung 32" G32A FullHD Odyssey Gaming Monitor
Quicklinx: GQW6WS00 Mfr#: LS32AG320NUXXU
Diagonal Size: 32in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, HDMI
Hurry, only 1 left in stock!
£249.17 ex VAT
£299.00 inc VAT
React in real time 165Hz refresh rate Conquer every enemy, even at soaring speeds. 165Hz refresh rate eliminates lag and motion blur for exhilarating gameplay with ultra-smooth action.
Measure reactions in milliseconds 1ms response time (MPRT) Make every move count with a 1ms response time. Screen pixels change colour with near-instant response, enabling fast-paced action to flow with real-world accuracy. Your on-screen performance is as swift as your own reflexes.
Uninterrupted game flow AMD FreeSync Premium Effortlessly smooth gameplay. AMD FreeSync Premium features adaptive sync technology which reduces screen tearing, stutter, and input latency. Low framerate compensation ensures every scene flows seamlessly.
See your game your way Ergonomic design Reach the height of winning. Swivel, tilt and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
Take in the full view 3-sided borderless design Your legacy has no boundaries. The 3-sided borderless design unveils maximum space for bigger, bolder gameplay. Line up two displays precisely in a dual-monitor setup, so no enemies slip through the cracks.
Fresh eyes win more Eye Saver Mode & Flicker Free Play for even longer. Eye Saver Mode minimises blue light enough to keep eyes relaxed and comfortable when gaming for extended periods. Flicker Free technology continuously removes tiring and irritating screen flicker so you can focus longer with less distraction or eye strain.
  • 165Hz refresh rate
  • 1ms response time
    Make every move count with a 1ms response time. Jump on enemies as soon as you see them and stay ahead with precise mouse movements. Your on-screen performance is as swift as your own reflexes.
  • AMD FreeSync Premium
    Effortlessly smooth gameplay. AMD FreeSync Premium features adaptive sync technology, which reduces screen tearing, stutter, and input latency. Low framerate compensation ensures every scene flows seamlessly.
  • See your game your way
    Reach the height of winning. Swivel, tilt, and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
  • Full screen design
    Your legacy has no boundaries. The 3-sided borderless design unveils maximum space for bigger, bolder gameplay. Line up two displays precisely in a dual-monitor setup, so no enemies slip through the crack.
  • Fresh eyes win more
    Play for even longer. Eye Saver Mode minimizes blue light enough to keep eyes relaxed and comfortable when gaming for extended periods. Flicker Free technology continuously removes tiring and irritating screen flicker so you can focus longer with less distraction or eye strain.
Samsung Odyssey G3 S32AG320NU - LED monitor - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class E
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 165 Hz
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Voltage
AC 100/240 V (50/60 Hz)
71.92 cm x 24.88 cm x 59.74 cm
6.2 kg
Display Type
Energy Class
Class E
35 kWh
Diagonal Size
32"
Viewable Size
32"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (MPRT)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, Mega Dynamic Contrast Ratio, Black eQualizer, Flicker Free technology, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Refresh Rate Optimizer, 3 Side Borderless Design
71.92 cm x 24.88 cm x 59.74 cm - with stand
6.2 kg
HDMI , DisplayPort 1.2 , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
30
Rotation Angle
-2/+92
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
24 W
24 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption (Max)
48 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 71.92 cm - depth: 24.88 cm - height: 59.74 cm - weight: 6.2 kg , Without stand - width: 71.92 cm - depth: 9.37 cm - height: 43.48 cm - weight: 4.5 kg
Shipping Width
81.3 cm
Shipping Depth
22 cm
Shipping Height
56 cm
Shipping Weight
9.1 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 32in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
