The SP 300DN is perfect for shared use. With standard USB 2.0 and Ethernet 10 base-T/100 base-TX, it integrates smoothly into an office's existing network. Each print job can be sent to the most appropriate network machine, so users can collect their prints at the printer that is most convenient for them.
The SP 300DN is highly versatile. It takes a wide range of formats such as A4, A5, A6 and B5, and enables the use of plain and recycled paper up to 162 g/m². It prints on envelopes and transparencies, while confidential documents can be protected with a printed watermark.
As with all Ricoh products, reducing environmental impact is a prime focus. The SP 300DN has environmentally responsible and money-saving features such as short warm-up time, ultra-low sleep mode, duplex printing and increased toner yield. An Energy Saver mode and low Typical Electricity Consumption further reduce energy costs. In addition, Ricoh products are Energy Star compliant. This means less CO2 is produced in providing the energy needed to run Ricoh devices.
The Aficio SP 300DN is the latest addition to Ricoh's advanced range of digital office equipment. Ricoh currently manufactures one of the most extensive line-ups of printers, copiers, faxes and multifunctional devices, as well as advanced software solutions.
- Ricoh SP 300DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 12.5 kg
- Media Size Class
- A4
- Max Media Size
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 28 ppm - B/W
- Max Resolution (B&W)
- 1200 x 600 dpi
- Automatic Duplexing
- Interface
- USB, LAN
- Processor
- 295 MHz
- RAM Installed (Max)
- 64 MB
- Language Simulation
- PCL 5, PostScript 3, PCL 6
- Media Type
- Envelopes, plain paper, recycled paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 20000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - integrated
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Apple MacOS X 10.2.8-10.6
- 37 cm x 39.2 cm x 26.2 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 1200 x 600 dpi
- First Print Out Time B/W
- 8 sec
- Fonts Included
- 80
- Media Handling
- Processor
- 295 MHz
RAM
- 64 MB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 52 g/m² - 162 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , 1 x automatic - 50 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m²
- Max Media Capacity
- 550 sheets
- Output Trays Capacity
- 125 sheets
Duty Cycle
- 20000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- IPP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages
- ISO 9001, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 880 Watt
- Power Consumption Stand by / Sleep
- 5 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 37 cm
- 39.2 cm
- 26.2 cm
- 12.5 kg
