- Promethean ACTIVpanel Touch 55 - touchscreen - USB, VGA
- Touchscreen
- Connectivity Technology
- Wired - USB, VGA
- Display
- LCD display - 55" - 1920 x 1080
- 129 cm x 7.5 cm x 78.2 cm
- 42.1 kg
- Multi-Touch
- Movement Detection Technology
- Infrared
- Performance
- 8 ms response time
- Pressure sensitive pen, 10-point simultaneous touch
- Power
- AC 120/230 V
- OS Required
- Google Chrome OS, Ubuntu 12.04, Microsoft Windows Vista / XP / 7 / 8, Ubuntu 14.04, Apple MacOS X 10.6 - 10.10
- Touchscreen
- 129 cm
- 7.5 cm
- 78.2 cm
- 42.1 kg
Input Device
- Wired
- Interface
- USB, VGA
- Infrared
- Multi-Touch
- Performance
- Active Area
- 121 cm x 68 cm
Display
- LCD display
- Diagonal Size
- 55"
- Image Aspect Ratio
- 16:9
- Native Resolution
- 1920 x 1080
- Image Brightness
- 350 cd/m²
- Image Contrast Ratio
- 1400:1
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Response Time
- 8 ms
- 1 x USB 2.0 - 4 pin USB Type B , 1 x serial - RS-232 , 4 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x video - component video input - RCA x 3 , 1 x audio - input - mini-phone 3.5 mm , 1 x audio / video - composite video/audio input - RCA x 3 , 1 x USB - 9 pin USB Type A , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x audio / video - composite video/audio input - RCA x 3 , 1 x audio , 1 x headphones
- Included Accessories
- 2 interactive pens, 4 VESA mounting screws, infrared remote control, USB cable (5 m), HDMI cable, VGA cable, audio cable
- ISO 13406-2
- Voltage Required
- AC 120/230 V
- OS Required
- 5 °C
- 40 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
