The ActivBoard 500 Pro is a state-of-the-art interactive whiteboard with pen and intuitive multi-touch functionality. Designed to foster a true collaborative learning experience, the ActivBoard 500 Pro enables up to four students to work together simultaneously on a task. Images can be easily moved, scaled and rotated with finger touch in conjunction with real life pen tasks such as solving a math equation.
Powerful applications
The ActivBoard 500 Pro is designed to deliver excellent applications, emerging technologies and resources to more learners. -
More and extended learning opportunities
Bring hands-on activities to life with the ActivBoard 500 Pro's powerful multi-pen and multi-touch capabilities. Teachers and all types of learners will benefit from the intuitive and natural way of working with the ActivBoard 500 Pro. Utilize the ActivPen to ensure accuracy while students use the touch capability to manipulate objects modeled on real world behavior and gestures. -
Connect and share
USB power plus an accessible USB port simplifies connection to your computer.
- Promethean ActivBoard 578 Pro Mount System - interactive whiteboard - USB
- Interactive whiteboard
- Connectivity Technology
- Wired - USB
- Display
- Projector - 1280 x 800
- 186.8 cm
- Localisation
- United Kingdom
- Movement Detection Technology
- Electromagnetic
- Movement Resolution
- 2730 ppi
- Built-in stereo speakers, built-in 2-ports USB hub, low-glare surface
- Cables Included
- 1 x USB cable - 3 m
- Power
- AC 120/230 V
- OS Required
- Microsoft Windows XP SP3 or later, Microsoft Windows Vista / XP / 7, Ubuntu 9.10, Ubuntu 10.04, Apple MacOS X 10.4.11 - 10.6.4, Debian Lenny, Linex Colegios 2010, Linkat 3, ALT Linux
- 186.8 cm
- Localisation
- United Kingdom
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- 2730 ppi
- Active Area
- 162.8 cm x 117.5 cm
Display
- Projector
- Colour Support
- 16.8 million colours
- Native Resolution
- 1280 x 800
- Image Brightness
- 2500 lumens
- Image Contrast Ratio
- 2000:1
- 1 x USB
- Included Accessories
- 4 x ActivPen, wall mounting kit, EST-P1 DLP projector
- Cables Included
- UL, FCC
- Power supply
- Voltage Required
- AC 120/230 V
- OS Required
- System Requirements Details
- Core 2 Duo - 2 GHz - RAM 1 GB - HD 1.5 GB , MacOS X - Core 2 Duo - 2 GHz - RAM 512 MB - HD 3 GB , Linux 2 GHz - RAM 1 GB - HD 1.5 GB
- 0 °C
- 40 °C
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
