Promethean 500PRO Range 78" ActivBoard with Mobile Stand
Quicklinx: 8LW1WS00 Mfr#: ABMS578PEST-UK
The ActivBoard 500 Pro is a state-of-the-art interactive whiteboard with pen and intuitive multi-touch functionality. Designed to foster a true collaborative learning experience, the ActivBoard 500 Pro enables up to four students to work together simultaneously on a task. Images can be easily moved, scaled and rotated with finger touch in conjunction with real life pen tasks such as solving a math equation.
  • Powerful applications
    The ActivBoard 500 Pro is designed to deliver excellent applications, emerging technologies and resources to more learners.
  • More and extended learning opportunities
    Bring hands-on activities to life with the ActivBoard 500 Pro's powerful multi-pen and multi-touch capabilities. Teachers and all types of learners will benefit from the intuitive and natural way of working with the ActivBoard 500 Pro. Utilize the ActivPen to ensure accuracy while students use the touch capability to manipulate objects modeled on real world behavior and gestures.
  • Connect and share
    USB power plus an accessible USB port simplifies connection to your computer.
Promethean ActivBoard 578 Pro Mobile System - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
Display
Projector - 1280 x 800
186.8 cm x 90.9 cm x 199 cm
137.2 kg
United Kingdom
Movement Detection Technology
Electromagnetic / capacitive
Movement Resolution
2730 ppi
Performance
200 inches per second
Built-in stereo speakers, built-in 2-ports USB hub, low-glare surface, height adjustable
1 x USB cable - external - 3 m
AC 120/230 V
Microsoft Windows XP SP3 or later, Ubuntu 9.10, Ubuntu 10.04, Microsoft Windows Vista / 7, Apple MacOS X 10.4.11 - 10.6.4, Debian Lenny, Linex Colegios 2010, Linkat 3, ALT Linux
5-year warranty with product registration
186.8 cm
90.9 cm
199 cm
137.2 kg
United Kingdom
Input Device
Wired
USB
Movement Resolution
2730 ppi
Performance
Active Area
162.8 cm x 117.5 cm
Display
Projector
Colour Support
16.7 million colours
Native Resolution
1280 x 800
Image Brightness
2500 lumens
Image Contrast Ratio
2000:1
1 x USB 2.0
Wallmount brackets, 4 x ActivPen, EST-P1 DLP projector
UL, FCC
Power adapter
AC 120/230 V
System Requirements Details
Windows XP/Vista/7 - Core 2 Duo - 2 GHz - RAM 1 GB - HD 1.5 GB , MacOS X 10.4.11 - 10.6.4 - Core 2 Duo - 2 GHz - RAM 512 MB - HD 3 GB , Linux 2 GHz - RAM 1 GB - HD 1.5 GB
Limited warranty - whiteboard - 5 years , Limited warranty - ActivPen - 1 year , Limited warranty - projector - 3 years , Limited warranty - stand - 1 year
