Promethean 100 Range 64" ActivBoard with Mount System and DL
Quicklinx: 8969WS00 Mfr#: ABMTS164DST-UK
Learning journeys begin one step at a time, but even the most revolutionary efforts start with the basics. In the ActivClassroom, that's a classroom-tough interactive whiteboard and software package that brings the elements of education to life in a big way. The ActivBoard 100 Range is a great place to start.
The ActivBoard 100 Range features color, motion and interactivity at an economical price right for any school. In two sizes and with room to grow, the ActivBoard 100 Range is a perfect starting point for building your ActivClassroom. Add ActivSound for teacher and student amplification that makes listening to the lesson less of a strain. Choose ActivArena 50 to update to Dual-User functionality and make collaboration at the board a part of the instructing. Finally, use included ActivInspire Personal Edition software with inspirational resources, templates and activities to create a variety of educational experiences unlike any other. The possibilities are as vast as the landscape of learning.
Promethean ActivBoard 164 Mount System - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
Display
Projector - 1280 x 800
United Kingdom
Movement Detection Technology
Electromagnetic
Movement Resolution
2730 ppi
Low-glare surface
1 x USB cable - 5 m
Microsoft Windows XP SP2 or later, Ubuntu 8.10, Ubuntu 9.04, Mandriva Linux, Ubuntu 8.04, Apple MacOS X 10.4.11 - 10.6.1, Ubuntu 9.10, Microsoft Windows Vista / 7
United Kingdom
Input Device
Wired
USB
Electromagnetic
Movement Resolution
2730 ppi
Active Area
127.1 cm x 101.2 cm
Low-glare surface
Display
Projector
Colour Support
16.8 million colours
Native Resolution
1280 x 800
Image Brightness
2500 lumens
Image Contrast Ratio
2000:1
1 x USB
ActivPen, wall mounting kit
1 x USB cable - 5 m
UL, FCC
System Requirements Details
Pentium 4 - 1 GHz - RAM 512 MB - HD 1.5 GB , MacOS X 10.4.11 - 10.6.1 RAM 512 MB - HD 3 GB , Windows Vista - Pentium 4 - 800 MHz - RAM 512 MB - HD 1.5 GB
50 °C
