Philips P Line 329P1H 32" 2840x2160 4ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: G5HHWS00 Mfr#: 329P1H/00
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
39 In Stock
£502.61 ex VAT
£603.13 inc VAT
Master every task in a crisp view
The Philips USB-C docking display for a comprehensive solution. View UltraClear 4K UHD and re-charge a laptop up to 90 W, all at the same time with a single USB-C cable. Pop-up webcam with Windows Hello delivers performance and convenience.
USB-C enables laptop power charging directly from a monitor
This Philips display features a built-in USB type-C docking station with power delivery. With intelligent and flexible power management, you can power charge your compatible laptop directly. Its slim, reversible USB-C connector allows for easy, one-cable docking. Simplify by connecting all your peripherals like keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. You can watch high-resolution video and transfer data at super-speed, while powering up and re-charging your notebook at the same time.
UltraClear 4K UHD (3840 x 2160) resolution for precision
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
Securely sign in with pop-up webcam with Windows Hello™
Philips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello™ facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
TUV Eye Comfort certified to reduce eye fatigue
Philips displays meet TUV Rheinland Eye Comfort standard to prevent eye strain caused by prolonged computer use. With TUV Eye Comfort certification, Philips displays ensure flicker-free, low-blue mode, no disturbing reflections, a wide viewing angle, less reduction of image quality from different angles and ergonomic stand designs for an ideal viewing experience. Keep your eyes healthy and boost work productivity.
PowerSensor saves up to 80% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life
LightSensor for the perfect brightness with minimal power
LightSensor uses a smart sensor to adjust the picture brightness depending on the light conditions in the room for the perfect picture with minimal power usage.
Built-in RJ-45 Ethernet gives data security
EasyRead mode for a paper-like reading experience
  • PowerSensor
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life
Philips P-line 329P1H - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class G
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
40 W
2.0 megapixel camera, Gigabit Ethernet network adapter, USB 3.2 Gen 2 hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.18159 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
117% NTSC (CIE 1976), 128% sRGB (CIE 1931), 89% Adobe RGB (CIE 1976)
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Black texture
71.4 cm x 28 cm x 64.9 cm
12.2 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, TUV Ergo, DDC/CI, RoHS, EPA, cETLus, CU-EAC, TUV Eye Comfort certified, EAEU RoHS
Display Type
Energy Class
Class G
57 kWh
Diagonal Size
32"
Viewable Size
31.5"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.18159 mm
Pixel Per Inch
140
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
23 - 75 Hz
Horizontal Refresh Rate
30 - 140 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Lead-free, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, Adaptive-Sync technology, EasyRead, Delta E<2 calibration, Windows 10 Hello, SmartControl
Black texture
71.4 cm x 28 cm x 64.9 cm - with stand
12.2 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DisplayPort 1.4 (HDCP 2.2) , 2 x HDMI (HDCP 2.2) , USB-C 3.2 Gen 2 upstream/DisplayPort Alt Mode (HDCP 2.2) , Audio line-out , Network , 3 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream (fast charging)
Mechanical
Tilt Angle
-5/+25
Swivel Angle
360
Rotation Angle
180
Height Adjustment
180 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable with USB-C to USB-A dongle
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
40 W
40 kWh/1000h
Power Consumption (Typical)
31.8 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand (highest position) - width: 71.4 cm - depth: 28 cm - height: 64.9 cm - weight: 12.2 kg , Without stand - width: 71.4 cm - depth: 6.2 cm - height: 42.2 cm - weight: 8.19 kg
Shipping Width
93 cm
Shipping Depth
18.6 cm
Shipping Height
56.3 cm
Shipping Weight
15.51 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
20 - 80%
Diagonal Size: 32in
Response Time: 4ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Philips
Price Range Ex VAT: £500 - £750
