Concise design, complete in every detail
The Philips award-winning monitor gives crisp 4K and lifelike visuals with DisplayHDR 400 certified. Trimmed with all ports, one-cable USB-C and simple cable management design for a clean set-up. SmartErgo base for ergonomic adjustments.
Zero Bezel for a full picture and modern look
Eliminating the surrounding frame in our Zero Bezel design offers an expansive picture with a modern look and a virtually seamless experience for multi-monitor setups.
Cable management reduces cable clutter for a neat workspace
Cable management is an intimate design that maintains a tidy workspace by organising the cables and wires required for the operation of a display device.
Connect your notebook with one USB-C cable
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and recharging your compatible device at the same time.
UltraClear 4K UHD (3840 x 2160) resolution for precision
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
IPS LED wide view technology for image and colour accuracy
IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
Effortlessly smooth gameplay with AMD FreeSync™ technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. With the new Philips monitor it doesn't have to be. Get fluid, artefact-free performance at virtually any frame rate with AMD FreeSync™ technology, smooth, quick refresh and ultra-fast response time.
DisplayHDR 400 for more lifelike colourful visuals
VESA-certified DisplayHDR 400 delivers a significant step up from normal SDR displays. Unlike, other "HDR-compatible" screens, true DisplayHDR 400 produces astonishing brightness, contrast and colours. With global dimming and peak brightness up to 400 nits, images come to life with notable highlights while featuring deeper, more nuanced blacks. It renders a fuller palette of rich new colours, delivering a visual experience that engages your senses.
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
Power and re-charge compatible notebook from the monitor
This monitor features a built-in USB-C connector that meets USB Power Delivery standard. With intelligent and flexible power management, you can now power up and/or re-charge your compatible Notebook directly from the Monitor using a single USB-C cable.
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
IPS technology
IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
LowBlue Mode
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
UltraClear 4K UHD Resolution
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive. -
USB-C connection
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and recharging your compatible device at the same time. -
Ultra-smooth gaming
Gaming shouldn't be a choice between choppy gameplay or broken frames. With the new Philips monitor it doesn't have to be. Get fluid, artefact-free performance at virtually any frame rate with AMD FreeSync technology, smooth, quick refresh and ultra-fast response time. -
DisplayHDR 400
VESA-certified DisplayHDR 400 delivers a significant step up from normal SDR displays. Unlike, other"HDR-compatible" screens, true DisplayHDR 400 produces astonishing brightness, contrast and colours. With global dimming and peak brightness up to 400 nits, images come to life with notable highlights while featuring deeper, more nuanced blacks. It renders a fuller palette of rich new colours, delivering a visual experience that engages your senses. -
Zero Bezel
Eliminating the surrounding frame in our Zero Bezel design offers an expansive picture with a modern look and a virtually seamless experience for multi-monitor setups. -
Cable management
- Philips C-line 279C9 - LED monitor - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Power Consumption (On mode)
- 26 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.2/USB-C hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1554 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1300:1
- HDR Capable
- DisplayHDR 400
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 109% sRGB (CIE 1931), 90.7% NTSC (CIE 1976)
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black
- 61.2 cm x 21.8 cm x 52.7 cm
- 5.85 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV, ICES-003, CB, CCC, DDC/CI, RoHS, Lead-Free, ISO 9241-307, TUV Bauart, CECP, CEL, EPA, CU-EAC, Ukraine, Mercury-free, EAEU RoHS
- 2-year warranty
- Display Type
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- Diagonal Size
- 27"
- Viewable Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB 3.2/USB-C hub
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1554 mm
- Pixel Per Inch
- 163
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1300:1
- HDR Certification
- DisplayHDR 400
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Refresh Rate
- 30 - 140 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Multilingual
- Smart Ergo base, SmartImage Game, Mega Infinity Dynamic Contrast Ratio, Zero-Bezel Design, Low Blue Light Mode, Flicker Free technology, EasyRead, sRGB Mode
- Textured black
- 61.2 cm x 21.8 cm x 52.7 cm - with stand
- 5.85 kg
- DisplayPort 1.4 , 2 x HDMI , USB-C (power up to 65W) , 2 x USB 3.2 downstream , 2 x USB 3.2 downstream (fast charging) , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), DisplayPort Alt Mode
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable
- MTBF
- 50,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption HDR (On mode)
- 30 kWh/1000h
- Power Consumption (Typical)
- 25.72 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Included Software
- Philips SmartControl
- Dimensions & Weight Details
- With stand (highest position) - width: 61.2 cm - depth: 21.8 cm - height: 52.7 cm - weight: 5.85 kg , Without stand - width: 61.2 cm - depth: 3.9 cm - height: 35.3 cm - weight: 4.25 kg
- Shipping Width
- 68 cm
- Shipping Depth
- 15 cm
- Shipping Height
- 54.5 cm
- Shipping Weight
- 8.41 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 80%
