With this powerful Philips professional TV, vibrant picture quality is only the beginning. It gives you the edge when it comes to engaging guests.
Optimized for apps
The TVs are optimized for apps and you can install web apps directly to the display, too. -
Wireless presentations
Enable hassle-free wireless casting of movies, presentations and more from smart devices to your Philips professional TV.
- Philips 43HFL5014 Professional MediaSuite - 43" LED-backlit LCD TV - for hotel / hospitality
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 43"
- Commercial Use
- Yes - hotel / hospitality
- Black
- Platform
- Android
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- Mobile High-Definition Link (MHL)
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Analogue TV Tuner
- PAL
- Internet Streaming Services
- HbbTV, Chromecast
- Commercial Features
- VSecure, mychoice, Serial Xpress Protocol, Double isolation Class II, CMND management, SecureMedia
- Settings Cloning Capability
- Speaker System
- 2 speakers
- Sound Effects
- DTS Studio Sound
- Storage Drive Capacity
- 16 GB
- Storage Capacity
- 16 GB
- USB
- 2 ports
- Included Accessories
- Philips 22AV1905A remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class F
- Power Consumption (On mode)
- 48 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 71 kWh
- Dimensions (WxDxH) - without stand
- 97 cm x 8.05 cm x 56.25 cm
- 7.2 kg
- Product Type
- Energy Class
- Class F
- 48 W
- Power Consumption SDR (On mode)
- 48 kWh/1000h
- 71 kWh
- Diagonal Class
- 43"
- Commercial Use
- Series
- Professional MediaSuite
- Platform
- Android
- Operating System
- Android OS
- TV Tuner Presence
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Eco mode
- Design
- Flame retardant cabinet
- Dimensions
- Without stand
- 97 cm
- 8.05 cm
- 56.25 cm
- 7.2 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- 16:9
- LED backlight
- Brightness
- 250 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- One touch Play
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
- VESA Compatibility
TV Tuner
- Analogue TV Tuner
- PAL
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- MHEG
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG, Now & Next
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, AVC, H.264, VC-1, HEVC, VP9
- Supported Audio Formats
- MP3, WMA, WAV, AAC, WMA Pro
- Supported Pictures Formats
- BMP, JPG, GIF, PNG
- USB Port
- USB Ports Qty
- 2
- Configuration
- 16 GB
- 16 GB
Remote Control
- Remote control
- Remote Control Model
- Philips 22AV1905A
- Battery Form Factor
- AAA type
Audio System
- Digital Audio Format
- Dolby Digital output, DTS-HD digital output, Dolby Atmos, Dolby AC-4 output
- Surround Mode
- Sound Effects
- DTS Studio Sound
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Down-firing Speaker, Audio Return Channel (ARC)
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11ac
- Connect & Share
- Wi-Fi Direct, Secure Sharing
- HbbTV, Chromecast
- Application Store
- Google Play
- Connector Type
- Digital audio output (optical) - rear , LAN - rear , HDMI - side , Remote control - rear , USB 2.0 - rear , Speakers output - rear , USB 3.0 - side , HDMI - rear , Headphones - side
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- WOL (Wake on LAN)
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 97 cm x 8.05 cm x 56.25 cm x 7.2 kg , Panel with stand - 97 cm x 19.4 cm x 62.4 cm x 7.3 kg
- 0 °C
- 40 °C
