Enhance and personalize interactions with this user-friendly touch screen. Using the power of touch, a brand high level of interactivity is available. With the projected capacitive touch technology, this display offers a bezel-less front, complete with simultaneous touch points. Meaning users can interact with your business in new, dynamic ways.
Communicate wirelessly with the Wi-Fi and Bluetooth integration or simplify your content control by downloading content wirelessly.
Internal memory
Save and play content with internal memory. Upload your media into the display and playback content immediately. Working in conjunction with the internal browser, it also serves as a memory cache when streaming online content. If the network ever fails, the internal memory keeps content running by playing a cached version of the content, ensuring that your media stays up even if the network goes down. -
Power-over-Ethernet
Simplify the installation with Power-over-Ethernet technology. Using this technology, power and connectivity can be delivered over a single Ethernet line. This allows for a simplified installation, since there is no need for a power adapter. Displays can be installed in small, hard to reach areas, helping to ensure a more flexible and adaptable display environment. And for those who prefer not to use Power-over-Ethernet, a power adapter is included in the box. -
Multi-touch interactivity
Using the power of touch, a brand high level of interactivity is available. With the projected capacitive touch technology, this display offers a bezel-less front, complete with simultaneous touch points. Meaning users can interact with your business in better, dynamic ways. -
Smart browser
Connect and control your content via the cloud with the integrated HTML5 browser. Using the Chromium based browser, design your content online and connect a single display, or your complete network. Simply connect the display to the internet using Wi-Fi or with an RJ45 cable, and enjoy your own created playlists. -
Wi-Fi and Bluetooth
Communicate wirelessly with the Wi-Fi and Bluetooth integration or simplify your content control by downloading content wirelessly. -
CMND
A robust display management platform, CMND puts the power back into your hands. From content management to settings, you can control it with CMND. -
Powered by Android
With Android integrated into the touch display, you can work with the most dveloped OS on the planet, and save your own app directly into the display. This also means, for the built-in apps, like the browser, it's touch capable right out of the box. Just connect the power and you've got immediate interactivity. You can also use the built-in scheduler to daypart your apps and content based on the time of day. And, using the auto orientation feature, switching from portrait to landscape content is as simple as turning the display. -
CMND & Control
With CMND & Control, easily manage multiple displays in a central location. With real time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier. -
CMND & Create
Design and create compelling content with CMND & Create, a powerful authoring tool. With a drag and drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content.
- Philips Signage Solutions 24BDL4151T 24" Class (23.6" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with camera
- Diagonal Class
- 24"
- Diagonal Size
- 23.6"
- Commercial Use
- Yes - digital signage
- Platform
- Android
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- DVI, VGA (HD-15)
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Advanced Colour Management
- Speaker System
- 2 speakers
- Storage Drive Capacity
- 16 GB
- Storage Capacity
- 16 GB
- Supported Memory Cards
- microSDHC
- USB
- Energy Class
- Class G
- 25 Watt
- Power Consumption (On mode)
- 24.1 W
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 56.65 cm x 4.92 cm x 36.11 cm
- 4 kg
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 25 Watt
- 24.1 W
- Power Consumption SDR (On mode)
- 24.1 kWh/1000h
- Diagonal Class
- 24"
- Diagonal Size
- 23.6"
- Commercial Use
- Combined With
- Camera
- Platform
- Android
- Operating System
- Android OS 7.1.2
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Acceleration sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 56.65 cm
- 4.92 cm
- 36.11 cm
- 4 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 1000:1
- Brightness
- 250 cd/m²
- Viewing Angle
- 170 degrees
- Viewing Angle (Vertical)
- 160 degrees
- Touchpoints Qty
- 10
- Response Time
- 5 ms
- Display Menu Language
- Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- Backlight Life
- 50,000 hour(s)
- PoE support, Projected Capacitive Touch (PCT), tempered glass (1.5mm)
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 100 x 100 mm
- VESA Compatibility
Media Player
- microSDHC
- USB Port
- Configuration
- 16 GB
- 16 GB
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 4 Watt
- Speakers
- 2 x speaker - 2 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Gigabit Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11ac
- Connector Type
- mPCIe slot , HDMI input , HDMI output , Headphones , USB 2.0 , USB 3.0
- FCC Class A certified, UL, TUV, C-Tick, GS, IEC 60950, CB, CCC, PSE Mark
- Power Device
- Power supply
- 0.5 Watt
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 30 - 80%
