Panasonic TH-42LF25E 42in HD LCD Plasma
Quicklinx: 80MFWS00 Mfr#: TH-42LF25E
  • 1080p
In addition to the high resolution of Full-HD and the wide viewing angle of the IPS panel, the LF25 series features 500-cd/m2 brightness and 9-ms response. This makes it possible to display crisp, clear images even in bright places, for signage with excellent information transmission performance.
The LF25 series has various input terminals including component or RGB input, composite video input, S-Video input, PC input and RS-232C control port input. It's also equipped with HDMI 1/2 inputs with deep color, and DVI-D input with HDCP for high definition signals.
  • Versatile functions for public information displays
  • Standard features include highly versatile terminals
  • Narrow bezel and multi display
    The bezel on the TH-42LF25ER is only 18.3 mm wide. It is a most suitable model for multi screen display. The video image and graphics can be displayed in greatly by using two or more displays. The effect of the digital signage a high noteworthy level is achieved by decorating the wall with the video image.
  • Eco mode
    The light sensor detects the ambient light level and control the brightness of the backlight accordingly. This maintains optimum display brightness. It also helps to save energy by reducing the backlight power consumption.
Panasonic TH-42LF25ER LF25 - 42" LCD flat panel display - Full HD
Diagonal Class
42"
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
Remote control
Voltage
AC 230V (50/60 Hz)
240 Watt
96.8 cm x 10.1 cm x 56.1 cm
18 kg
240 Watt
Diagonal Class
42"
Series
LF25
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, 1:1 Pixel Mode, Seam Hides Video Mode
Design
Fanless Design
Protection
Dustproof
96.8 cm
10.1 cm
56.1 cm
18 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Image Contrast Ratio
1200:1
Brightness
500 cd/m²
Widescreen Modes
Zoom
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Backlight Life
50,000 hour(s)
Multi-display setup, Automatic Picture Positioning
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 720 x 400, 852 x 480, 1152 x 900, 1360 x 768, 640 x 400, 1920 x 1080, 1280 x 800, 1066 x 600, 1400 x 1050
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
10 Watt
Speakers
2 x main channel speaker - 5 Watt
Connector Type
Composite video input , S-Video input , 2 x audio line-in , 2 x HDMI input , Component video input , DVI-D input , VGA input , Audio line-in , Serial
Plug and Play, GOST, DDC-2B, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60065, IEC 60065
Power supply - internal
Input Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by / Sleep
0.2 Watt
Auto On/Off
Width (Shipping)
110 cm
Depth (Shipping)
21 cm
Height (Shipping)
70.7 cm
Weight (Shipping)
23 kg
20 - 80% (non-condensing)
