Olympus TG-4 Tough Camera Red 16MP 3.0LCD
Quicklinx: C1Q7WS00 Mfr#: V104160RE000
The Tough TG-4 is rugged enough to go anywhere, but its powerful imaging technology makes this camera very versatile. Sophisticated features like RAW capture, nighttime Live Composite, and the super-bright wide-angle zoom lens create amazing images no matter how challenging the environment, while built-in Wi-Fi, fast GPS, and the multifunction compass help you to find, shoot, and share your adventures like never before.
  • Rugged technology
    Whether you snorkel or surf, ride or ski, bike or hike, or love to shoot outdoors, the TG-4 is up to the challenge. It's waterproof, and its rugged inner and outer chassis construction protects the lens assembly from force and impact. Plus, the TG-4 is freeze proof and dustproof, so there's never a reason to leave it at home.
  • RAW power
    TG-4 captures lifelike images with an unmatched combination of features. You can shoot in RAW for high resolution and maximum creative control. With Olympus' advanced BSI CMOS Sensor and the TruePic VII image processor, you will capture small details and bright colors of every exciting moment.
  • Fast and bright
    Always be ready to shoot. TG-4's high-speed wide-angle lens captures light fast, and the lightning-quick FAST AF technology keeps the focus sharp. Nail blur-free shots as quick as the action happens, and shoot crisp, detailed images with minimal noise in low light. Plus, the Aperture Priority Mode expands your focus range and shooting control for amazing results.
  • Advanced shooting modes
    Advanced shooting modes are readily at your fingertips via the Mode Dial. Powerful Macro Modes shoot close, like the Microscope Control mode. Underwater Modes shoot crystal clear, including the Underwater HDR mode that uses composite technology to enhance light and shadow. Nighttime Live Composite mode automatically combines multiple images into a single photograph for stunning night scenes and star trails.
  • Shoot anywhere, share everywhere
    Find your adventure and find your way back! GPS pinpoints your location in a few seconds, while the compass tracks barometric pressure, altitude, and water depth as it points the way home. With built-in Wi-Fi, share your shots.
Olympus Stylus Tough TG-4 - digital camera
Digital camera - 1080p - compact
Memory Card Slot
SD card
Image Processor
TruePic VII
Sensors
Magnetometer, pressure sensor
Wireless Interface
Wireless LAN
Sensor Resolution
16.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 4x zoom - 4.5 - 18 mm - f/2.0-4.9
Focus Adjustment
Automatic
Min Focus Distance
10 cm
Digital Zoom
4x
Image Stabiliser
Optical (image sensor shift mechanism)
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
Olympus Li-92B Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Red
11.15 cm x 3.12 cm x 6.59 cm
247 g
Built-in Light
LED lights
Enclosure Colour
Red
Sensor Resolution
16.0 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
16,800,000 pixels
Effective Sensor Resolution
16,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
4x
Digital Zoom
4x
Image Processor
TruePic VII
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Navigation
GPS receiver
Sensors
Print Standard
DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Advanced Face Detection technology, face-priority AF function
Digital Video Format
AVI, MJPEG, H.264, MOV
Image Recording Format
JPEG, RAW
1920 x 1080
Composite video/audio, HDMI, USB 2.0, Wireless LAN
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 6400, ISO 3200, ISO auto
Exposure Metering
Multi-segment, spot
Exposure Modes
Programme, automatic, aperture-priority
Shooting Programs
Landscape, portrait mode, beach/snow, night portrait, self-portrait, fireworks, panorama assist, night scene, Underwater, sports mode, sunset, indoor, cuisine, snow, documents, e-portrait, handheld starlight, backlight correction HDR, microscopic macro
Bracketing Modes
Focus bracketing
Special Effects
Vivid, fisheye, soft focus, natural, Muted, Diorama, Grainy Film, Pop Art, Pale & Light Colour, pin hole, dramatic, Reflection, Fragmented
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, sunlight, tungsten light, Underwater
Max Shutter Speed
1/2000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
25 - 100mm
Focus Adjustment
Automatic
Min Focus Distance
10 cm
Macro Focus Range
1cm
Zoom Adjustment
Motorised drive
Lens Construction
7 groups / 9 elements
Filter Size
40.5 mm
Built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.2 m - 7.9 m: ISO 1600 (wide lens) , 0.2 m - 3.1 m: ISO 1600 (tele lens)
Additional Features
Continuous Shooting Speed
5 frames per second, 15 frames per second (3MP), 60 frames per second (3MP)
Self-Timer Delay
2sec, 12sec, 1 - 30 sec
Additional Features
Audio recording, built-in speaker, RGB primary colour filter, date/time stamp, histogram display, AF lock, cropping an image, resizing an image, in-camera red-eye fix, interval shooting mode, USB charging, Shadow Adjustment Technology, tap control, Intelligent AUTO (iAUTO), high-speed recording, Time-Lapse recording, Super Resolution Zoom
Display
3" LCD display
Display Format
460,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , HDMI output (19 pin micro HDMI Type D) , Composite video/audio output
Software
Software
Drivers & Utilities, Olympus Viewer 3
AC power adaptor, USB cable, wrist strap
Protection
Waterproof, crushproof, freezeproof, shockproof, dust-resistant
Underwater Use
Underwater Depth
Up to 15 m
Battery Type
Olympus Li-92B Lithium Ion
Details
Battery Life Details
Photo shooting - 380 shots , Video recording - 2 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Memory Card Included
No
Image Storage
JPEG 4608 x 3456 , JPEG 3264 x 2448 , JPEG 2048 x 1536 , JPEG 640 x 480 , RAW 4608 x 3456
11.15 cm
3.12 cm
6.59 cm
247 g
-10 °C
