Quality you can trust
Designed, built and tested with the same passion as all Nokia products, T20 brings that trusted quality to the big screen, so you have one less thing to worry about – even if your day gets a bit bumpier.
Do what you love for longer
A tablet with an all-day battery life - Nowadays, long battery life is a necessity. Nokia T20 comes with enough power to see you through up to 7 hours of online meetings, 10 hours of movies or 15 hours of surfing the web. Plus, faster charging means you can get back to what you were doing even quicker. From conference calls to science class, the power is yours.
Delight in every sight
See every detail with a 2K display - Nokia T20 makes light work of your day-to-day (and night) viewing with a captivating 2K screen. So, whether you’re viewing a work presentation on the go, or just relaxing at home with a movie, every detail will look fantastic. It's also low blue light certified...so it’s easier on the eyes.
Conquer any battlefield
Whether you’re playing games or multi-tasking across a few apps, you need a device that keeps up. Thankfully, Nokia T20 is boasts power to spare, with an octa-core chip ensuring a faster, more reliable user experience, even when pushed to the max. In short, there’s some serious power under this hood.
Immersed in sound
You need to be able to catch every word of every meeting, and when the day is done, enjoy your favourite entertainment with the stunning sound it deserves. Stereo speakers with OZO Playback deliver truly immersive listening experience - wherever you are.
Designed, built and tested with the same passion as all Nokia products, T20 brings that trusted quality to the big screen, so you have one less thing to worry about - even if your day gets a bit bumpier. -
Nowadays, long battery life is a necessity. Nokia T20 comes with enough power to see you through up to 7 hours of online meetings, 10 hours of movies or 15 hours of surfing the web. Plus, faster charging means you can get back to what you were doing even quicker. From conference calls to science class, the power is yours. -
Nokia T20 makes light work of your day-to-day (and night) viewing with a captivating 2K screen. So, whether you're viewing a work presentation on the go, or just relaxing at home with a movie, every detail will look fantastic. It's also low blue light certified... so it's easier on the eyes. -
Whether you're playing games or multitasking across a few apps, you need a device that keeps up. Thankfully, Nokia T20 is boasts power to spare, with an octa-core chip ensuring a faster, more reliable user experience, even when pushed to the max. In short, there's some serious power under this hood. -
Immersed in sound
You need to be able to catch every word of every meeting, and when the day is done, enjoy your favorite entertainment with the stunning sound it deserves. Stereo speakers with OZO Playback deliver truly immersive listening experience - wherever you are. -
Take your tablet anywhere
Protect your Nokia T20 against drops and scratches with purpose-built rugged accessories.
- Nokia T20 - tablet - Android 11 - 64 GB - 10.4" - 3G, 4G
- Product Type
- Tablet
- Operating System
- Android 11
- Display
- 10.4" - 1200 x 2000 - Multi-Touch
- Processor
- Unisoc Tiger T610 (8-core)
- Processor Clock Speed
- 1.8 GHz
- Storage
- 64 GB
- RAM
- 4 GB
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Cellular Technology
- 3G, 4G
- Cellular Protocols
- GSM, WCDMA, LTE, FDD LTE, TDD LTE
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Rear Camera
- 8 Megapixel focus: automatic
- Front Camera
- 5 Megapixel
- Navigation System
- GPS/A-GPS
- Radio Tuner Type
- FM radio
- Security Devices
- Face recognition
- 15.75 cm x 0.78 cm x 24.76 cm
- 470 g
- Deep ocean
- Specific Absorption Rate (SAR)
- 1.35 W/kg (body)
- Product Type
- Tablet
- Operating System
- Android 11
Display
- 10.4"
- Resolution
- 1200 x 2000
- Touchscreen
- Multi-Touch
- Image Brightness
- 400 cd/m²
- In-cell touch technology, toughened glass, brightness boost
- Processor
- Unisoc Tiger T610
- 1.8 GHz
- Number of Cores
- 8-core
- Storage
- 64 GB
- RAM
- 4 GB
- Max Supported Capacity
- 512 GB
Communications
- 3G, 4G
- Band
- W-CDMA B1/B5/B8 / LTE B1/B20/B28/B3/B38/B40/B41/B5/B7/B8
Rear Camera
- Sensor Resolution
- 8 Megapixel
- Focus Adjustment
- Automatic
- Light Source
- LED flash
Front Camera
- Sensor Resolution
- 5 Megapixel
Navigation System
- Receiver
- GPS/A-GPS
Multimedia
- Radio Tuner Type
- FM radio
- Audio
- Two microphones, stereo speakers with amplifier
Input Device
- Security Devices
- Face recognition
Software
- Preloaded Software
- Google Kids Space
Expansion and Connectivity
- Expansion Slots
- 1 x microSDXC , 1 x Nano-SIM card
- USB-C/USB 2.0 , Headphones mini jack (3.5mm)
- Capacity
- 8200 mAh
- Deep ocean
- Case Material
- Sandblasted aluminium
- Face Unlock
- Included Accessories
- SIM card ejection tool, 10W charger
- IP52, Widevine L1 Certification, SGS Low Blue Light Certification
- 1.35 W/kg (body)
- 15.75 cm
- 0.78 cm
- 24.76 cm
- 470 g
