- NETGEAR DGN2200 - wireless router - DSL modem - 802.11b/g/n - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- TCP/IP
- Routing Protocol
- RIP-1, RIP-2
- Remote Management Protocol
- SNMP, HTTP
- Firewall protection, DMZ port, DoS attack prevention, content filtering, Intrusion Detection System (IDS), Intrusion Prevention System (IPS), parental control, wall mountable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Multiple SSID support, ReadySHARE
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
- Power
- AC 240 V (50 Hz)
- Environmental Standards
- ENERGY STAR Qualified
- 17.3 cm x 12.8 cm x 3.3 cm
- 300 g
- System Requirements
- Apple MacOS, Microsoft Windows 2000/ME/XP/Vista/7
- Localisation
- United Kingdom
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- TCP/IP
- Routing Protocol
- RIP-1, RIP-2
- SNMP, HTTP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, VCCI Class B ITE, CISPR 22 Class B, EN55022 Class B, FCC Part 15 B, RoHS, WEEE, CEC
- Status Indicators
- Port status, power, link/activity
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , USB: 1 x 4 pin USB Type A
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Power Device
- External power adapter
- Voltage Required
- AC 240 V (50 Hz)
- ENERGY STAR Certified
- Included Accessories
- Vertical stand, POTS filter
- Cables Included
- 1 x network cable , 1 x phone cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 17.3 cm
- 12.8 cm
- 3.3 cm
- 300 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
