The Wireless-N 300 Router with DSL Modem Mobile Broadband Edition is a full featured wireless-n router with integrated ADSL2+ modem and a failover or backup option to connect to a 3G/4G/WiMAX mobile broadband network in case of DSL outage. Internet traffic will be temporarily routed via the secondary mobile broadband Internet access. When normal service is restored to your primary ADSL line, all traffic is switched back. The mobile broadband connection can also be used as a primary Internet connection in situations where no DSL/cable/satellite connection exists. When not using the backup option, the router can be used to share a USB storage device with any computer in the network. The solution is ideal for small and medium businesses that need the reliability of an always-on Internet connection.
The Wireless-N 300 Router with DSL Modem Mobile Broadband Edition is ideal for both professional and personal Internet use, providing Wireless-N speed and mobile hotspots for simultaneous downloads, voice and music, and online gaming. Complete with a built-in DSL modem and automatic WAN backup, it keeps you online during DSL outages.
Built-in DSL modem
ADSL2+ modem and router combined create complete gateway for DSL Internet connection. -
Stay connected
DSL with 3G+ backup, create Wi-Fi hotspot, automatic WAN backup keeps you online during DSL outages. -
Faster downloads and online gaming
Provides Wireless-N speed for simultaneous downloads, streaming voice and music and online gaming, in addition to basic Internet applications. -
Guest network access
Provides separate security and access restrictions for guests using the network. -
Broadband usage meter
Monitors Internet traffic and sends customized reports to help keep costs under control. -
Secured connection
Push 'n' connect offer a secured wireless Internet connection at the push of a button.
- NETGEAR DGN2200M - Mobile Broadband Edition - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- HTTP
- Firewall protection, DoS attack prevention, IDS, IPS, parental control, firmware upgradable, QoS, WPS, ReadySHARE
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
- Environmental Standards
- ENERGY STAR Qualified
- 17.3 cm x 12.8 cm x 3.3 cm
- 300 g
- System Requirements
- Apple MacOS, Microsoft Windows 2000/XP/Vista/7
- Localisation
- United Kingdom
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- HTTP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, RoHS, WEEE
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- ENERGY STAR Certified
- Included Accessories
- Vertical stand, POTS filter
- Cables Included
- 1 x network cable , 1 x phone cable , 1 x USB extension cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 17.3 cm
- 12.8 cm
- 3.3 cm
- 300 g
