Your basket is empty
NETGEAR ProSAFE XS716T 16 Port 10G Switch
16 Port 10 Gigabit Smart Managed Switch
Quicklinx: C4NNWS00 Mfr#: XS716T-100NES
Type: 10 Gigabit Ethernet
Ports: 16
Managed: Yes
£1,201.04 ex VAT
£1,441.24 inc VAT
The XS716T 10-Gigabit Ethernet Smart Managed Switch brings the second generation of 10-Gigabit Copper switching to SMBs. The XS716T is a powerful Smart Managed Switch that includes 16 ports of 10-Gigabit connectivity (16 copper with 2 shared combo copper/SFP+ Fiber ports). NETGEAR's 10-Gigabit Smart Managed Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. The XS716T provides comprehensive L2+/Layer 3 Lite features (including IPV6 management) allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It can be used at the "center of a small business network" or as an aggregation/access switch in a larger organization. The XS716T is ideal for smaller workgroups that need high-bandwidth for sharing, collaborating, editing, and publishing high-density content like video or animation.
NETGEAR ProSAFE XS716T - switch - 16 ports - smart - rack-mountable
Switch - 16 ports - L3 Lite - smart
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
16 x 10GBase-T + 2 x shared 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 320 Gbps , Forwarding performance (64-byte packet size): 238 Mpps
ACL: 100 , Virtual interfaces (VLANs): 512 , IGMP groups: 512 , IPv4 routes: 32 , IPv6 routes: 32 , Priority queues per port: 8 , ARP entries: 738 , DHCP snooping entries: 8000
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IP address filtering, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, Dynamic ARP Inspection (DAI), reset button, LACP support, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), Strict Priority Queuing (SPQ), 2MB packet buffer, Class of Service (CoS), 802.1x authentication, Type of Service (ToS), DiffServ Code Point (DSCP) support, 2 fans, cable test, layer 2+ switching
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
44 cm x 20.4 cm x 4.3 cm
2.98 kg
Latin America, North America, Europe
NETGEAR lifetime warranty
Bundled Services
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
RADIUS, TACACS+
Cortex-A9: 600 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Port transmission speed, power, link/activity, fan
16 x 10GBase-T - RJ-45 , 2 x 10GBase-X - SFP+ , 1 x USB 2.0 - management
Internal power supply
96 Watt
Rubber feet
Rack Mounting Kit
Included
MTBF
276,832 hours
cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, CISPR 22, CCC, FCC Part 15 A, C-Tick Class A, SCC, VCCI Class A, TLS v1.2, TLS v1.0, EN 55024
Software Included
Drivers & Utilities
44 cm
20.4 cm
4.3 cm
2.98 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
C4NN C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.13
C4NN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.16
C4NN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.73
C4NN C2G 2m Cat6a Shielded Patch - Blue In Stock £6.95
C4NN C2G TruLink Media Gateway RJ45 Cap In Stock £0.54
C4NN C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £44.02
Ports: 16
Managed: Yes
Brand: NETGEAR
Price Range Ex VAT: 1000 - 1500
