NETGEAR's SRXN3205 ProSafe Wireless-N VPN Firewall offers two types of virtual private network (VPN) tunnels, Secure Sockets Layer (SSL) and IP security (IPsec), for optimal secure connection to your network. SSL VPN tunnels provide clientless remote access to your corporate data for individual access anywhere and anytime without a software client. IPsec VPN tunnels deliver both secure site-tosite tunnels and legacy remote access support, connecting multiple offices together, as well as clientbased remote access. Backed by a sophisticated firewall, the SRXN3205 is a high-performance, SNMP-manageable security solution that furnishes multidimensional security including denial-ofservice (Dos) protection, stateful packet inspection (SPI), URL keyword filtering, logging, reporting, and real-time alerts. Four Gigabit LAN ports in conjunction with an integrated dual band Wireless N Access Point keep your data moving at top speed.
The SRXN3205 Wireless-N VPN Firewall takes care of all your security needs, with support of up to 5 SSL VPN tunnels and 5 IPsec VPN tunnels simultaneously, hacker protection via SPI firewall, Dos attack protection, and multiple VPN pass-through. SYSLOG and email reporting enable thorough network monitoring. The SSL VPN tunnels support industry-strength encryption algorithms and features such as automatic cache cleanup after session termination to ensure protection and privacy of your sensitive data. The SRXN3205 Wireless-N VPN Firewall provides optimal value and defense against network security threats.
Enhanced security
With a suite of encryption algorithms including 128-bit WEP, 256-bit AES, and Triple DES, alongside firewall protection, stateful packet inspection (SPI), and VPN support, the NETGEAR ProSafe SRXN3205 ensures your network remains secure against external threats. -
Robust connectivity
This wireless router supports a wide range of data link protocols including Ethernet, Fast Ethernet, Gigabit Ethernet, and 802.11a/b/g/n (draft 2.0), ensuring versatile and high-speed connectivity options for all your devices. -
Comprehensive VPN support
Offering up to 5 SSL and IPSec VPN tunnels, the device facilitates secure and efficient remote access, making it suitable for businesses with remote employees or multiple office locations.
- NETGEAR ProSafe SRXN3205 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Performance
- VPN throughput: 20 Mbps , Throughput: 60 Mbps
- Capacity
- SSL VPN tunnels: 5 , IPSec VPN tunnels: 5 , Concurrent connections: 20000
- IPSec
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 2, HTTP
- Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), Syslog support, SPI, DoS attack prevention, E-mail alert, VPN passthrough, URL filtering, QoS, DHCP server
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft 2.0)
- 25.3 cm x 18 cm x 3.5 cm
- 1.3 kg
- Localisation
- Europe
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Performance
- Capacity
- IPSec
- Routing Protocol
- Static IP routing
- SNMP 2, HTTP
- Encryption Algorithm
- DES, Triple DES, MD5, ARCFOUR, 128-bit WEP, 64-bit WEP, SHA-1, TLS 1.0, SSL 3.0, PEAP, TTLS, TKIP, WPA, WPA2, PKI, 256-bit AES
- Authentication Method
- RADIUS
- Processor
- 300 MHz
- RAM
- 64 MB
- Flash Memory
- 16 MB
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- Europe
- Software Included
- Drivers & Utilities, ProSafe VPN Client (1 user licence)
- 25.3 cm
- 18 cm
- 3.5 cm
- 1.3 kg
- 0 °C
- 40 °C
