Your ports, where you want them
Today's networks have increasing numbers of devices attached to them. As wired devices proliferate, it can be difficult to easily and neatly place networked ports where you want them.
NETGEAR ProSAFE Click Switches™ address this issue head on.
These innovative Gigabit Ethernet switches come with an industry-first, bracket mounting system for easy installation. With a flexible and unique 1-2-3-4 click arrangement, it's easier than ever to enable optimal placement and cable management in locations where other switches will not go.
Vertical/side mount, Vertical/rear mount, Horizontal/side mount and Horizontal/rear mount.
- Available in either 8- or 16-Gigabit port configurations
- Slim design with internal power supplies
- Sleek cable management system
- USB charging ports on GSS108E
- Prioritise and manage bandwidth usage with intuitive web browser as seen on the ProSAFE Plus series
Put an end to unsightly cables and switch placement challenges. Deliver a better way for customers to put their ports, where they want them. Available now, click here for your Click Switch from authorised NETGEAR channels.
- NETGEAR Plus GSS108E - switch - 8 ports - smart
- Switch - 8 ports - smart
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Bandwidth: 16 Gbps
- Capacity
- Virtual interfaces (VLANs): 64 , Layer 2 multicast groups: 128
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 16KB
- Remote Management Protocol
- HTTP
- Flow control, VLAN support, IGMP snooping, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, firmware upgradable, vertical mounting, TFTP support, QoS, horizontal mounting, plastic housing, fanless, DHCP client, Energy Efficient Ethernet, 2MB packet buffer, loop prevention, Multicast filtering function, CoS, tagged VLAN, ToS, DSCP support
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- 30.5 cm x 6.5 cm x 3.5 cm
- 440 g
- Localisation
- United Kingdom, Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Capacity
- 8K entries
- 16KB
- HTTP
- Status Indicators
- Port transmission speed, power, link/activity
- 8 x 1000Base-T RJ-45 , 2 x USB (power only) Type A
- Power Device
- Internal power supply
- 20.1 Watt
- Included Accessories
- Cable retaining straps, 1-2-3-4 mounting kit
- MTBF
- 1,031,177 hours
- CISPR 22 Class B, cUL, EN 60950, IEC950, UL 1950, CSA 22.2 No. 950, EN50082-1, EN55022 Class B, C-Tick Class B, FCC Part 15 B, EN55024 Class B, CCC Class B, VCCI Class B
- Localisation
- Software Included
- Drivers & Utilities
- 30.5 cm
- 6.5 cm
- 3.5 cm
- 440 g
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
- 0 °C
- 40 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
