The NETGEAR WNDAP660 AP supports 3 x 3 multiple-input multiple-output (MIMO) with three spatial streams to deliver up to 50% faster throughput speeds and improved service area coverage. Advanced wireless security with Wireless Intrusion Prevention Services (WIPS), Wireless Intrusion Detection Services (WIDS) and RF management make the NETGEAR access point the economical solution for small-and mid-sized businesses seeking a secure and efficient way to manage their multi-faceted wireless traffic needs.
- NETGEAR Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Connection / user qty: 128
- Power Over Ethernet (PoE) Supported
- PoE+
- 25.38 cm x 25.38 cm x 5.48 cm
- 1.5 kg
- NETGEAR lifetime warranty
- 25.38 cm
- 25.38 cm
- 5.48 cm
- 1.5 kg
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 450 Mbps
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, SSH, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Status Indicators
- Power, LAN, wireless, link/activity
- Auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, MIMO technology, wall mountable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, wireless bridge mode, LLDP support, rogue access point detection, ceiling mountable, Wireless Intrusion Prevention System (WIPS)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
- Authentication Method
- Secure Shell (SSH), RADIUS, Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.3at
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Gain Level
- 2 dBi
- 2 x 1000Base-T - RJ-45 , 3 x aerial , 1 x management - RJ-45
- Cables Included
- 1 x network cable
- Mounting Kit
- Included
- PoE+
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities
