The FS100 series Fast Ethernet switches bring the 100 Mbps switching technology in a compact form factor to the small office marketplace at an aggressive price. These switches segment networks for improved performance, enabling the most demanding multimedia and imaging applications. Since each port is auto-speed-sensing, individual hubs or directly attached servers can easily be upgraded from 10 to 100 Mbps.
- NETGEAR FS105 10/100 Desktop Switch - switch - 5 ports
- Switch - 5 ports
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- MAC Address Table Size
- 1000 entries
- Full duplex capability, auto-sensing per device, store and forward
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 9.4 cm x 10.3 cm x 2.7 cm
- 0.28 kg
- Localisation
- English / United Kingdom
- NETGEAR lifetime warranty
- Switch - 5 ports
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- 1000 entries
- RAM
- 64 KB
- Status Indicators
- Port status, port transmission speed, power, link/activity
- 5 x 100Base-TX RJ-45
- Power Device
- External power adapter
- Voltage Required
- 7.5 Watt
- Mounting Kit
- Included
- MTBF
- 393,000 hours
- Plug and Play, C-Tick, CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55022 Class A, FCC Part 15 A
- Localisation
- Software Included
- Drivers & Utilities
- 9.4 cm
- 10.3 cm
- 2.7 cm
- 0.28 kg
- Limited warranty - power supply - 2 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
Customer reviews
Write a review for the NETGEAR ProSafe FS105 10/100 Desktop Switch - switch - 5 ports here!
Perfect
Reviewed by Mark Elder. Review Posted 05/01/2007
Netgear gets it right again. Does what it says it will.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
