NETGEAR's ProSafe Dual WAN Gigabit Firewall with SSL & IPsec VPN offers the best of both worlds by offering two types of virtual private network (VPN) tunnels, Secure Sockets Layer (SSL) and IP security (IPsec), for optimal secure connection to your network. SSL VPN tunnels provide clientless remote access to your corporate data for individual access anywhere and anytime while IPsec VPN tunnels provide both secure site-to-site tunnels and legacy support for client-based remote access. Backed by a true firewall, this VPN router is a high-performance, SNMP-manageable, network solution that furnishes multidimensional security including denial-of-service (Dos) protection, stateful packet inspection (SPI), URL keyword filtering, logging, reporting, and real-time alerts. Four Gigabit LAN ports keep your data moving at top speed while two Gigabit WAN ports provide load-balancing and failover protection to ensure maximum throughput and reliable connectivity to the Internet. With Network Address Translation (NAT) routing and classical routing, up to 253 users can access your broadband connection at the same time.
Secure
The FVS336G takes care of all your security needs, with support of up to 25 IPsec VPN tunnels and 10 SSL VPN tunnels simultaneously, hacker protection via SPI firewall, Dos attack protection, and multiple VPN pass-through. SYSLOG and email reporting enable thorough network monitoring. IKE authentication provides peace of mind against unauthorized VPN network access. The SSL VPN tunnels support industry-strength encryption algorithms and features such as automatic cache cleanup after session termination to ensure protection and privacy of your sensitive data. Dedicated DMZ port allows you to segregate externally accessible assets from internal PCs. The ProSafe Dual WAN Gigabit Firewall provides optimal value and defense against network security threats. -
Reliable
Dual Gigabit Ethernet WAN ports support two broadband connections, in either a load-balancing or fail-over configuration. The load-balancing configuration enables maximum throughput by utilizing both WAN connections to distribute traffic across two broadband connections, possibly with different ISP providers. Alternatively, the second WAN port may be configured as a failover connection in case the primary connection fails, for another method of providing high reliability. -
Easy to use
Auto detect connects to your ISP quickly; the user-friendly web-based ProSafe control center configuration screen and install assistant reduce setup time. With SSL VPN tunnels, employees can quickly and securely access company data with just a web browser without going into the office. The IPsec VPN wizard automates IPsec VPN configuration and secure remote makes it simple to connect to multiple sites. Support for DHCP (client and server) as well as PPPoE allows for easy, widespread deployment.
- NETGEAR ProSafe FVS336Gv2 - router - desktop
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 2
- Data Link Protocol
- Performance
- Throughput: 60 Mbps , VPN throughput (3DES IPSec): 16 Mbps , VPN throughput (SSL): 10 Mbps
- Capacity
- IPSec VPN tunnels: 25 , Concurrent SSL VPN sessions: 10 , Concurrent sessions: 10000
- TCP/IP, UDP/IP, NTP, ICMP/IP, IPSec, PPPoE, SMTP, FTP, DHCP, DNS, POP3
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- Telnet, SNMP 2c, HTTP, HTTPS
- Firewall protection, DMZ port, auto-sensing per device, dynamic IP address assignment, DHCP support, NAT support, VPN support, load balancing, auto-uplink (auto MDI/MDI-X), Syslog support, SPI, DoS attack prevention, content filtering, ALG support, E-mail alert, MAC address filtering, VPN passthrough, URL filtering, QoS, IPSec NAT-T, DHCP server, DNS proxy
- 25.4 cm x 17.8 cm x 3.96 cm
- 1.7 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, RSA, MD5, ARCFOUR, IKE, SHA-1, TLS 1.0, SSL 3.0, DSA, PKI, 128-bit AES, 256-bit AES
- Authentication Method
- X.509 certificates
- Processor
- 1 x 300 MHz
- RAM
- 64 MB SDRAM
- Flash Memory
- 16 MB
- Status Indicators
- Port transmission speed, power, link OK, test mode, link/activity
- WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- Europe
- Software Included
- Drivers & Utilities, ProSafe VPN Client (1 user licence)
- 25.4 cm
- 17.8 cm
- 3.96 cm
- 1.7 kg
- Limited warranty - power supply - 3 years
- 0 °C
- 40 °C
- 0 - 90%
