NetGear Nighthawk X4S AC2600 Wireless Router DSL Modem 802.11a/b/g/n/ac Desktop
Quicklinx: B82HWS00 Mfr#: D7800-100UKS
  • IEEE 802.11n
Nighthawk X4S AC2600 Wi-Fi VDSL/ADSL modem router with MU-MIMO and Quad Stream technology delivers Wi-Fi to multiple devices simultaneously for faster speeds. Get ultimate Wi-Fi speeds, with a powerful processor. Enjoy smoother streaming and gaming by prioritizing application and device with Dynamic QoS.
  • Wave 2 MU-MIMO technology
    When multiple devices are connected to the router, each device needs to take its turn and then wait before receiving more data. This leads to slower network and Internet speeds. MU-MIMO technology delivers high-speed data streams to up to three devices simultaneously, so there's less waiting, boosting overall network speeds for all Wi-Fi devices.
  • Dynamic QoS
    Reduce buffering and lag while gaming or streaming. Based on an advanced application and device aware prioritization technology, Dynamic QoS intelligently allocates bandwidth to the most important activities in your home.
  • Powerful processors
    Make sure you have enough processing power to run all the network-heavy applications throughout your connected home. With an unmatched processor, you'll have unparalleled performance for gaming, streaming and mobile connectivity.
  • Built for gaming, streaming and mobility
    Take gaming and streaming to the advanced level. Multi-user MIMO (MU-MIMO) and Quad Stream technology delivers Wi-Fi to multiple devices simultaneously for faster speeds while Dynamic QoS prioritizes Internet traffic by application and device for lag-free connections. Roam freely on your mobile devices with increased range from Quad-Stream Wave 2 Wi-Fi. Beamforming+ and four high-powered antennas and amplifiers increase coverage, dependability and performance.
  • Storage
    The twin USB 3.0 ports and eSATA port provide speed and flexibility when you connect your external storage to your Nighthawk X4S. Enjoy fast, wireless access to your high-capacity hard drives from anywhere.
NETGEAR Nighthawk X4S AC2600 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2.53 Gbps
Remote Management Protocol
HTTP
Firewall protection, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), FTP server, ReadySHARE, Push ā€˜Nā€™ Connect button, DLNA Media Server, Beamforming+, MU-MIMO technology
28.5 cm x 18.5 cm x 5 cm
840 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2.53 Gbps
HTTP
Encryption Algorithm
WPA, WPA2
Wi-Fi Rating
AC2600
1 x 1.4 GHz
RAM
512 MB
Flash Memory
128 MB
Line Properties
Line Coding Format
256 QAM
Communications
DSL modem
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A , Phone line: 1 x VDSL2 / ADSL2+ - RJ-11 , Storage: 1 x eSATA - 7 pin external Serial ATA
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
POTS filter
1 x network cable , 1 x phone cable
United Kingdom
Software Included
NETGEAR Genie
28.5 cm
18.5 cm
5 cm
840 g
Technical support - phone consulting - 90 days
