The NETGEAR N150 Wireless ADSL2+ Modem Router is a simple and secure way to share your high-speed Internet connection at Wireless-N speeds for surfing the Internet, email, online chat and Facebook. Complete with all-in-one DSL modem and WiFi router, it is compatible with all major DSL Internet service providers and Wireless-G networks, allowing hassle-free connection flexibility.
All-in-one DSL modem -- ADSL2+ modem and router combined create complete gateway for DSL Internet connection
Compatibility -- Compatible with all major DSL Internet service providers (ISPs).
Surf, email, chat -- Wireless-N connection for basic Internet applications like surfing the Web, email and Facebook
Share Internet connection -- Allows Internet broadband sharing and the freedom of wireless Internet usage
Live Parental Controls -- Keeps your Internet experience safe
Blocks unsafe Internet content and applications and can be managed from anywhere
Protects connected devices through the router such as PCs, gaming consoles, and iPod touch®
To learn more visit www.netgear.com/lpc
Secured connection -- Push `N' Connect offers a secured wireless Internet connection at the push of a button
NETGEAR Green features -- Power and Wi-Fi on/off buttons, Energy Star-compliant power adapter and 80% recycled packaging
- NETGEAR DGN1000 - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 150 Mbps
- Routing Protocol
- RIP-1, RIP-2
- Remote Management Protocol
- HTTP
- Firewall protection, DMZ port, NAT support, SPI, DoS attack prevention, IDS, VPN passthrough, IPS, wall mountable, WMM support, event log, WPS, DHCP server, Live Parental Controls, Push ‘N’ Connect button
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup
- Power
- AC 230V (50 Hz)
- Environmental Standards
- ENERGY STAR Qualified
- 17.8 cm x 13 cm x 3.1 cm
- 265 g
- Localisation
- United Kingdom
- 1-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 150 Mbps
- Routing Protocol
- RIP-1, RIP-2
- HTTP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup, VCCI Class B ITE, CISPR 22 Class B, EN55022 Class B, FCC Part 15 B, RoHS, WEEE, CEC
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
- Antenna Qty
- 1
- Gain Level
- 2 dBi
- Power Device
- External power adapter
- Voltage Required
- AC 230V (50 Hz)
- ENERGY STAR Certified
- Cables Included
- 1 x network cable , 1 x phone cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- 17.8 cm
- 13 cm
- 3.1 cm
- 265 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
