Hang on - your network will soar when it is hooked up to NETGEAR's FS608! This powerful plug-and-play switch connects at 10 or 100 Mbps and makes it easy to link as many as eight computers or peripherals to your Ethernet network. You'll experience maximum performance for 10 or 100 Mbps devices with eight ports that automatically sense the correct speed while Auto Uplink on the ports adjusts for the different types of Ethernet cables. The FS608's sleek case has lights on the front for easy monitoring. Installation into your home network couldn't be simpler and, once powered on, it begins cool and silent operation - without an internal fan.
- NETGEAR FS608 - switch - 8 ports
- Switch - 8 ports
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100
- MAC Address Table Size
- 1K entries
- Flow control, auto-sensing per device, MDI/MDI-X switch, auto-negotiation
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3x
- 17.5 cm x 11.8 cm x 2.8 cm
- 0.3 kg
- System Requirements
- Apple MacOS, Linux, Microsoft Windows
- 3-year warranty
- Switch - 8 ports
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100
- 1K entries
- RAM
- 128 KB
- Status Indicators
- Port status, power, link/activity
- 8 x 100Base-TX RJ-45
- Power Device
- External power adapter
- 3.7 Watt
- Rack Mounting Kit
- Not available
- Plug and Play, FCC Class B certified, TUV, C-Tick
- Software Included
- Drivers & Utilities
- OS Required
- 17.5 cm
- 11.8 cm
- 2.8 cm
- 0.3 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
