5 Gigabit Ethernet ports
4 PoE+ ports with 63W total power budget
Simple plug-and-play setup with no software to install or configuration needed
Supports desktop or wall mount placement
Silent operation ideal for noise sensitive environment
- NETGEAR GS305P - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000 (4 PoE)
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 55.5 W
- Fanless
- 3-year warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 55.5 W
- Fanless
- Status Indicators
- Power, PoE, link/activity
- 4 x 1000Base-T RJ-45 PoE , 1 x 1000Base-T RJ-45
- Plug and Play
- Limited warranty - 3 years
