Get the ultimate 3D experience with a 3D ready DLP projector from NEC. DLP-Link technology allows 3D images to be projected with the aid of a single projector and active glasses without special screens, filters or emitters. The impression of 3D is created by the interaction with the active LCD shutter glasses. The easy to set up alternative to traditional 3D stereo projection! It's an ideal solution for classrooms, (small) meeting rooms, cross-use (private/professional), mobile/cooperative applications.
- NEC V230X - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Brightness
- 2300 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 180 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 233 Watt
- 31 cm x 9.5 cm x 24.7 cm
- 2.5 kg
- 3-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 2300 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 1.2 m - 13 m
- Throw Ratio
- 1.95 - 2.15:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 180 Watt
- Bulb life cycle
- Eco-Mode technology, 6-segment colour wheel, wall colour correction, BrilliantColor, DLP 3D Ready, VIDI Lighting Technology
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 7 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 pin mini-DIN
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- TUV GS, RoHS, ErP Ready
- Voltage Required
- 233 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- 31 cm
- 9.5 cm
- 24.7 cm
- 2.5 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 31 dB
