Enjoy large images even in meeting rooms with small space. Less shadow and glare gives the presenter more space to engage with his audience and enhances the experience with interactive white boards. Go wide with your presentations and play video content in native aspect ratio. Free installation angles give you additional freedom for eye catching digital signage installations. DLP technology ensures that there is no color decay during long daily operating hours. It is an ideal solution for meeting rooms and digital signage applications, as well as for classrooms.
Almost no shadow and glare
There is almost no shadow and glare thanks to ultra-short throwing distance. -
Wall-mount included
Wall-mount included is for quick and easy installation, compatible with height adjustable systems. -
Free tilting
Free tilting is for desktop use as well as ceiling and floor projection. -
Great connectivity
Great connectivity is due to numerous analog and digital connection terminals as well as network capability. -
Wide format
Wide format is for extra space in presentations and video content in native aspect ratio - no quality loss due to format scaling.
- NEC U310W - DLP projector - 3D
- DLP projector - 720p
- 3D Capable
- Built-in Devices
- Speaker
- Brightness
- 3100 lumens
- Contrast Ratio
- 1800:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 280 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 360 Watt
- 32.7 cm x 39.3 cm x 13.9 cm
- 6.3 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3100 lumens
- Contrast Ratio
- 1800:1
- Image Size
- 196 cm - 254 cm
- Projection Distance
- 0.148 m - 0.311 m
- Throw Ratio
- 0.3:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 280 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- 6-segment colour wheel, wall colour correction, BrilliantColor, DLP 3D Ready, VIDI Lighting Technology
Lens
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -15 / +15
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
Input Device
- External
- 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x HDMI input , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
- Included Accessories
- Wall mounting kit, remote control
- Cables Included
- 1 x VGA cable - 3 m
- Security Features
- Plug and Play, TUV GS, RoHS, EuP Ready
- Voltage Required
- 360 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- 32.7 cm
- 39.3 cm
- 13.9 cm
- 6.3 kg
- EMEA warranty - 3 years , EMEA warranty - lamp - 6 months / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 36 dB
- Sound Emission (Economic Mode)
- 32 dB
