NEC MultiSync V321 32" LCD flat panel display - HD - for digital signage
Quicklinx: 7224WS00 Mfr#: 60002699
Entry to the world of professional LCD public displays! It offers reliability and variability that is expected by demanding customers.
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1366 x 768
Display Format
720p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
Video Interface
Component, composite, HDMI, S-Video
PC Interface
DVI, VGA (HD-15), HDMI
HDCP Compatible
S-PVA
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
XtraView+
Sound Output Mode
Stereo
Speaker System
Speakers not included
Remote control
Microsoft Certification
Works with Windows Vista
Voltage
120 Watt
78.9 cm x 13.3 cm x 47.6 cm
13.1 kg
120 Watt
Diagonal Class
32"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
PC Interface
HDCP Compatible
XtraView+
78.9 cm
13.3 cm
47.6 cm
13.1 kg
Display
LCD Display Technology
S-PVA
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.511mm
Response Time
8 ms
Max V-Sync Rate
85 Hz
Max H-Sync Rate
91.1 kHz
No Touch Auto Adjust, front panel lockout, Rapid Response technology, TileComp, TileMatrix
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Video Features
16:9 Mode
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
Supported Computer Resolutions
1440 x 1050, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1920 x 1080
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
External Speakers Amplifier Power (Total)
14 Watt
Connector Type
Composite video output , Composite video input , 2 x audio input , Audio input , Serial input , Serial output , LAN , VGA input , VGA output , DVI-D input , HDMI input , S-Video input , Audio output , 2 x speakers output , Component video input
VGA cable
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
CCC
Power supply - internal
Input Voltage
On / Off Switch
No
On/off timer
