Take your environmental initiatives to the level with the 23" NEC MultiSync E231W, a widescreen LCD desktop monitor that enhances your desktop computing with bar-setting, eco-friendly benefits. The E231W features an LED-backlit panel that provides the same brightness as other panel types while using 35% less power. Compared to previous generation NEC LCDs, this model consumes less power overall, radiates less heat, uses less packaging, weighs less, utilizes recycled plastics in its production and is free of hazardous materials such as mercury, halogen and arsenic. These advantages, combined with an ergonomic design and a high-contrast screen, make this model ideal for enterprise environments.
XtraView
NEC MultiSync E231W delivers wide viewing angles of up to 176º horizontally and vertically (up to 88º up, down, left and right) with less color shift and without any glare, reflection or distortion. -
Ambix
NEC MultiSync E231W allows up to 3 inputs VGA, DVI-I and DVI-D to be connected to a single monitor. It also allows for each of the three signals to be displayed with the press of a button. -
Rapid response
NEC MultiSync E231W provides for uninterrupted display of full motion video with response times as quick as 4ms. It delivers streaming video without noticeable ghosting or blurring, while achieving as many as 250 frames per second (fps). This remarkably quick motion makes displays better than ever for gaming and video applications such as presentations and streaming web video. -
Eco-mode
Eco-mode conserves energy by allowing you to define a setting for the backlight at a 50 or 75% brightness level. Also calculates power saving in watts per hour. -
NTAA
No Touch Auto Adjust (NTAA) allows the monitor's image settings to be automatically adjusted to optimal settings upon initial power on. -
sRGB
A recommended default color setting that helps achieve a consistent color environment for PC-based applications. With sRGB, the image colors seen by the user on his/her screen can be reproduced elsewhere, such as printers. -
OSD
On Screen Display (OSD) controls allow users to quickly and easily adjust all elements of their screen image via simple-to-use on screen menus.
- NEC MultiSync E231W - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- Panel Type
- TN
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 25000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- White, silver
- 55 cm x 21.4 cm x 38.1 cm
- 6.2 kg
- Microsoft Certification
- Certified for Windows Vista
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2Bi, MPR III, PCT, CCC, TUV Ergo, ISO 9241-307, GEEA, ErP Ready
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 34 kWh
- Diagonal Size
- 23"
- Panel Type
- TN
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 170
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, colour balance
- Ambient light sensor, ErgoDesign, Eco-Mode
- White, silver
- 55 cm x 21.4 cm x 38.1 cm - with stand
- 6.2 kg
- VGA , DVI-D , DisplayPort
Mechanical
- Tilt Angle
- 25
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x DVI cable , 1 x VGA cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 23 W
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by / Sleep
- 0.34 Watt
- Dimensions & Weight Details
- Without stand - width: 55 cm - depth: 7.1 cm - height: 32.9 cm , With stand - width: 55 cm - depth: 21.4 cm - height: 38.1 cm - weight: 6.2 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
