Easy to use and at the right price, M series projectors using the DLP(R) technology from Texas Instruments provide all the essential features that you need to connect with your audience. The 3200-lumen, WXGA (1280 x 800) native resolution NEC M322W is ideal for education and small-to-medium-sized business environments that need essential features, including bright images, automatic technologies and eco-friendly appeal. The M322W offers lamp life up to 8,000 hours and a high contrast ratio of up to 10,000:1, while Crestron Roomview aids in emergency messaging. The versatile, color-coded connections to various sources aid in classroom and conference room use, including those in healthcare environments where its DICOM Simulation technology can be utilized. AutoSense(TM) intuitively syncs the projector with most computer signals and features one touch optimization. The environment is kept in mind with ECO Mode technology, a carbon savings meter, extended filter life, and energy-saving features such as quick startup and direct power off.
- NEC M322W - DLP projector - 3D - LAN
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DMD Chip
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 10000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 225 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60), LAN
- Video Modes
- 480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 224 Watt
- 36.79 cm x 28.59 cm x 9.75 cm
- 3.48 kg
- 3-year warranty
- 3D Capable
- Networking
- Ethernet
Projector
- Microdisplay
- DMD Chip
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 10000:1
- Image Size
- 76.2 cm - 762 cm
- Projection Distance
- 0.76 m - 13.53 m
- Throw Ratio
- 1.2 - 2.04:1
- Digital Zoom Factor
- 1.7x
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
- 16:10
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 225 Watt
- Bulb life cycle
- Controls & Adjustments
- Mute, volume, input select, keystone correction, zoom, aspect control, off timer
- Eco-Mode technology, freeze frame, wall colour correction, DLP 3D Ready, Crestron RoomView, Intelligent Power Management, DICOM Simulation Mode, Filter Free, auto power on, USB Viewer, ambient light sensor, Carbon Savings Meter
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.4-3.1
- Zoom Type
- Manual
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -25 / +25
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- HDMI, composite video, RGB
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 20 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB - 4 pin USB Type A , 1 x 3D Sync out
- Included Accessories
- Carrying case, wireless remote control, security label
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
- RoHS, GOST-R, ErP Ready, EAC
- Voltage Required
- 224 Watt
- Power Consumption Stand by
- 0.4 Watt
- Software Included
- NaViSet Administrator 2
- 36.79 cm
- 28.59 cm
- 9.75 cm
- 3.48 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 38 dB
- Sound Emission (Economic Mode)
- 30 dB
