Get great performance while saving the environment. Advanced Eco features help to substantially lower your operating cost without compromising on quality and flexibility. The M230X is particularly suited for classrooms and small meeting rooms.
- NEC M230X - LCD projector - portable
- LCD projector
- Built-in Devices
- Speaker
- Brightness
- 2300 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 180 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 239 Watt
- 33.9 cm x 25.7 cm x 9.9 cm
- 2.9 kg
- 3-year warranty
- LCD projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 2300 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 63.5 cm - 762 cm
- Projection Distance
- 0.6 m - 13.8 m
- Throw Ratio
- 1.3 - 2.2:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 180 Watt
- Bulb life cycle
- Eco-Mode technology, JPEG photo playback, wall colour correction, Auto Vertical Keystone
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.7-2.2
- Zoom Type
- Manual
- Zoom Factor
- 1.7x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x management - RJ-45 , 2 x USB 2.0 downstream - 4 pin USB Type A , 1 x USB upstream - 4 pin USB Type B
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- Security lock slot (cable lock sold separately), password protection, control panel lock
- TUV GS, RoHS, GOST-R
- Voltage Required
- 239 Watt
- Power Consumption Stand by
- 0.4 Watt
- Software Included
- Drivers & Utilities
- 33.9 cm
- 25.7 cm
- 9.9 cm
- 2.9 kg
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 34 dBA
- Sound Emission (Economic Mode)
- 27 dBA
