With its high-bright, professional-grade panel and remarkable contrast ratio (3500:1), the 46" NEC MultiSync X461HB displays images at amazing brightness levels no matter the lighting condition. Ideal for environments heavy with ambient light, this model boasts 110% higher brightness than NEC's previous-generation displays while consuming only 50% more power. The result is an image that outperforms that of displays with standard brightness, which can appear dim or washed out when placed in areas with high ambient light. The X461HB's unrivaled screen performance is enhanced by 30+ advanced features of the digital signage technology suite, including advanced thermal protection.
Thermal protection
It starts with an extra thermal layer on the display panel to diffuse heat followed by fan-based technology specially designed to work in both landscape and portrait modes and be controlled locally or remotely. -
Built-in expansion slot
Built-in expansion slot future-proofs your display investment, allowing for seamless integration of NEC and third-party components, including an HD-SDI card, single-board computer and DVI daisy chain capability. -
Sealed panel design
It provides protection in less than optimal environments, while protecting against particles like dust, grease, or steam from getting behind the glass and damaging the unit. -
Ambient light sensor
Automatically adjusts the backlight and power management depending on the ambient lighting brightness. -
Multi-display control and daisy chain
Enabled through RS-232, allows for individually addressable display control, making setup and monitoring of the display simple and effective. -
Ethernet Control and Communication
Provides the highest level of remote display management and includes such features as automatic email notification for diagnostic purposes. -
Carbon footprint meter
Informs and motivates responsible use of the display by calculating and tracking carbon savings. -
Improved auto-detection scheme
Improved auto-detection scheme allows for user customization of input selection. -
Quick input change
Quick input change speeds up transitions from one input mode to another. -
Real-time clock/round-the-clock scheduling
It allows for advanced scheduling of monitor powering up/down and input selection. These features also allow your messaging to be customized for time of day as well as improving energy savings and extending display life. -
Advanced screen saver functions
These include an array of features designed to reduce the risk of image persistence and extend display life. A gamma adjustment feature reduces the effect of high-contrast images, while a side color function allows adjustment of the color to minimize the contrast delta. -
CableComp+
This technology uses a digitized signal delay circuit to automatically compensate for each red, green and blue cable's length and video signal delay, ensuring sharp image reproduction.
- NEC MultiSync X461HB 46" LCD flat panel display - HD
- Product Type
- LCD flat panel display
- Diagonal Class
- 46"
- Black
- Resolution
- 1360 x 768
- Display Format
- 720p
- Input Video Formats
- 480p, 480i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI, S-Video
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- S-PVA
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- XtraView+
- Sound Output Mode
- Stereo
- Speaker System
- Speakers not included
- Included Accessories
- Remote control
- Microsoft Certification
- Certified for Windows Vista
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- 320 Watt
- Dimensions (WxDxH) - without stand
- 106 cm x 14 cm x 60.9 cm
- 31 kg
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 320 Watt
- Diagonal Class
- 46"
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor
- Video Interface
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode
- XtraView+
- Timer Functions
- Countdown
- Dimensions
- Without stand
- 106 cm
- 14 cm
- 60.9 cm
- 31 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1360 x 768
- Display Format
- 720p
- 16:9
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3500:1
- Brightness
- 1500 cd/m²
- Widescreen Modes
- 16:9
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.7455 x 0.7455mm
- Response Time
- 8 ms
- V-Sync Rate at Max Res.
- 60 Hz
- Max V-Sync Rate
- 85 Hz
- Max H-Sync Rate
- 91.1 kHz
- Eco TV, AmbiBright, AutoBright Technology, NaViSet, Scheduler Function (with RTC), TileMatrix (10 x 10), Digital Signage Technology Suite (DSTS), Rapid Response technology, CableComp, TileComp, TileMatrix
Video Wall
- 100
Stands & Mounts
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- 16:9 Mode
- Analogue Video Input Signals
- NTSC, PAL, SECAM
- Supported Computer Resolutions
- 1366 x 768, 1440 x 1050, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Speaker System
- External Speakers Amplifier Power (Total)
- 30 Watt
- Connector Type
- RGB input , RGB output , HDMI , DVI-Digital , VGA input , Component video input , Composite video output , Composite video input , S-Video input , Composite video input , 2 x audio line-in , Audio line-in , Audio line-out , 2 x serial , LAN , 4 x speakers output
- Expansion Slots
- 1 x Expansion Slot
- Cables Included
- VGA cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, DDC-2Bi, VESA DPMS, CCC, PSB, DDC/CI
- Power Device
- Power supply - internal
- Input Voltage
- Power Consumption Stand by / Sleep
- 1 Watt
- On/off timer, energy save
- Limited warranty - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel with stand - 106 cm x 35.1 cm x 64.5 cm x 32.9 kg
