The Cisco Meraki MS425-32 is a 32-port 10GbE cloud-managed stackable L3 enterprise-class aggregation switch with two QSFP+ 40G uplinks and support for redundant power supplies for mission critical environments. The MS425 family includes integrated client and layer 7 application visibility, remote troubleshooting tools like live packet capture and cable test. The MS425 family is 100% cloud-managed via the intuitive, browser-based Meraki dashboard, and includes a rich, out-of-the-box feature set without additional cost and complexity.
- Cisco Meraki Cloud Managed Ethernet Aggregation Switch MS425-32 - switch - 32 ports - Managed - rack-mountable
- Switch - 32 ports - Managed - stackable
- Enclosure Type
- Front to back airflow rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x 10 Gigabit SFP+ + 2 x 40 Gigabit QSFP+ (uplink)
- Performance
- Switching capacity: 800 Gbps
- Capacity
- Tagged VLANs: 4095
- Routing Protocol
- OSPFv2, static IP routing
- Layer 3 switching, DHCP support, VLAN support, IGMP snooping, port mirroring, E-mail alert, Broadcast Storm Control, firmware upgradable, STP support, RSTP support, QoS, SMS alert, LLDP support, LACP, Zero Touch Auto Provisioning, tagged VLAN, cloud managed
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ad, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (47 - 63 Hz)
- 48.5 cm x 48.7 cm x 4.5 cm
- 6.35 kg
- Limited lifetime warranty
- Enclosure Type
- Subtype
- Ports
- Performance
- Capacity
- Routing Protocol
- Authentication Method
- RADIUS
- 24 x 1000Base-X SFP+ , 2 x 40Gbit LAN QSFP+ uplink/stacking , 1 x management (Gigabit LAN) RJ-45
- Power Device
- Internal power supply
- Voltage Required
- MTBF
- 431,380 hours
- CSA, C-Tick, IC, RoHS
- 48.5 cm
- 48.7 cm
- 4.5 cm
- 6.35 kg
- Limited warranty - advance hardware replacement - lifetime - response time: next day
- 0 °C
- 40 °C
