Meraki MS425-32 L3 32-port Cloud Managed 10G SFP+ Switch
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQQ
Quicklinx: DV8KWS00 Mfr#: MS425-32-HW
Type: 10 Gigabit Ethernet
Ports: 32
Managed: Yes
£17,143.56 ex VAT
£20,572.27 inc VAT
The Cisco Meraki MS425-32 is a 32-port 10GbE cloud-managed stackable L3 enterprise-class aggregation switch with two QSFP+ 40G uplinks and support for redundant power supplies for mission critical environments. The MS425 family includes integrated client and layer 7 application visibility, remote troubleshooting tools like live packet capture and cable test. The MS425 family is 100% cloud-managed via the intuitive, browser-based Meraki dashboard, and includes a rich, out-of-the-box feature set without additional cost and complexity.
Cisco Meraki Cloud Managed Ethernet Aggregation Switch MS425-32 - switch - 32 ports - Managed - rack-mountable
Switch - 32 ports - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10 Gigabit SFP+ + 2 x 40 Gigabit QSFP+ (uplink)
Performance
Switching capacity: 800 Gbps
Tagged VLANs: 4095
Routing Protocol
OSPFv2, static IP routing
Layer 3 switching, DHCP support, VLAN support, IGMP snooping, port mirroring, E-mail alert, Broadcast Storm Control, firmware upgradable, STP support, RSTP support, QoS, SMS alert, LLDP support, LACP, Zero Touch Auto Provisioning, tagged VLAN, cloud managed
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ad, IEEE 802.1ab (LLDP)
AC 120/230 V (47 - 63 Hz)
48.5 cm x 48.7 cm x 4.5 cm
6.35 kg
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
Tagged VLANs: 4095
Routing Protocol
Authentication Method
RADIUS
24 x 1000Base-X SFP+ , 2 x 40Gbit LAN QSFP+ uplink/stacking , 1 x management (Gigabit LAN) RJ-45
Internal power supply
MTBF
431,380 hours
CSA, C-Tick, IC, RoHS
48.5 cm
48.7 cm
4.5 cm
6.35 kg
Limited warranty - advance hardware replacement - lifetime - response time: next day
Ports: 32
Managed: Yes
Brand: Meraki
Price Range Ex VAT: £1500+
