Linksys E2500 Wireless Router
Quicklinx: 7QGGWS00 Mfr#: E2500-UK
  • IEEE 802.11n
Linksys E2500 , Advanced Dual-Band N Router
Create a wireless network at home in a few easy steps with double the capacity for surfing the Internet, streaming multimedia and running applications simultaneously.
Ideal for:
- Larger households and teleworkers
- Surfing the web, emailing, printing wirelessly and connecting multiple devices
- Transferring and downloading large files
- Streaming multimedia and gaming
Key features*:
- Advanced Wireless-N router with wireless transfer speeds up to 300 + 300 Mbps
- Four Ethernet ports to connect wired devices
- Simultaneous Dual-Band to maximize throughput and help avoid network interference
- Setup in few easy steps with Cisco Connect
Superior wireless speed
The Linksys E2500 connects all your computers, tablets, Internet-ready TVs, game consoles and other devices at wireless transfer rates of up to 300 + 300 Mbps for an optimal home network experience.
Optimal wireless coverage
The enhanced MIMO antenna array offers increased signal strength to provide optimal coverage and reliability so you can enjoy wireless connectivity from anywhere in your home.
The power of Dual-Band
Double your network bandwidth with Dual-Band N (2.4 and 5 GHz) designed to avoid interference and maximize throughput ideal for HD media streaming, file transfers, and wireless gaming.
Advanced security
Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected.
Optimized for entertainment
Bring the ultimate entertainment experience to your home by connecting your computers, tablets, Internet-ready TVs, game consoles, media players and other devices to your wireless network and the Internet. The integrated QoS technology helps to prioritise latency-sensitive traffic which can help you to stream media, place a phone call or play multiplayer games without interruptions.
IPv6 ready
Supports the latest Internet Protocol technology to help you future-proof your network.
Quick to install
Cisco Connect helps you set up your wireless network in a few easy steps on a Windows or Mac computer.
Easy to manage
Cisco Connect works with Mac and Windows computers and helps you customize settings or quickly add new devices to your network. Cisco Connect enables you to:
  • Create a separate, password protected network for guests
  • Limit access time and access to certain websites with parental controls
  • Access advanced network settings easily
  • Measure your connection speed with the Broadband Speed Meter
  • Perform regular automated update checks for firmware and software with the option to install
  • Superior wireless speed
    The Linksys E2500 offers fast speed to connect your computers, wireless printers, game consoles, and other Wi-Fi devices at transfer rates up to 300 + 300 Mbps speed for an optimal home network experience.
  • Optimal wireless coverage
    Built with leading 802.11n wireless technology, the Linksys E2500 offers superior range to create a powerful wireless network. MIMO antenna array boosts signal strength to provide expanded coverage and reliability so you can enjoy your wireless network from anywhere in your home.
  • The power of dual-band
    Double your network bandwidth with dual-band N (2.4 and 5 GHz) designed to avoid interference and maximize throughput for smoother and faster HD video streaming, file transfers, and wireless gaming.
  • Advanced security
    Keep Wi-Fi freeloaders and Internet threats at bay with WPA/WPA2 encryption and SPI firewall to help keep your network protected.
  • Optimized for entertainment
    Bring the ultimate entertainment experience to your home by connecting computers, Internet-ready TVs, game consoles, media players and more to your wireless network and the Internet. QoS traffic prioritization technology is designed to deliver your time-sensitive Internet traffic efficiently so you can enjoy fast downloads, smooth video and music streaming, and gaming and VoIP.
Linksys E2500 - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
Routing Protocol
RIP, static IP routing
Remote Management Protocol
HTTP, HTTPS
128-bit encryption, NAT support, Stateful Packet Inspection (SPI), MAC address filtering, VPN passthrough, parental control, firmware upgradable, wall mountable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
22.5 cm x 18 cm x 3.5 cm
452 g
Microsoft Certification
Compatible with Windows 7
Microsoft Windows 7, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X 10.4.11 - 10.6.1
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
Routing Protocol
HTTP, HTTPS
Encryption Algorithm
128-bit WEP, 64-bit WEP, 40-bit WEP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, IC, FCC
Status Indicators
Port status, power
Line Properties
Line Coding Format
CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
1 x network cable
Software Included
Drivers & Utilities
22.5 cm
18 cm
3.5 cm
452 g
10 - 80% (non-condensing)
7QGG C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
