Linksys E2000 Advanced Wireless-N Dual Band Router (Cable Broadband Connections)
Quicklinx: 75S7WS00 Mfr#: E2000-UK
  • IEEE 802.11n
The Linksys E2000 offers Wireless-N technology and extended range to provide wireless coverage throughout your home. Selectable dual-band (2.4 GHz or 5 GHz) technology helps avoid network interference, enabling smoother file transfers and media streaming. Four Gigabit Ethernet ports allow for faster file transfers with other Gigabit devices. Plus, included Cisco Connect software gets you set up in a few simple steps and offers powerful tools for managing your wireless network. Easily customize your security settings, set Parental Controls, and access advanced settings.
  • Quick to install
    Cisco Connect software has three simple steps to get you set up and your secure wireless network is ready to go. A streamlined user interface allows you to choose from simple to advanced settings with no hassle.
  • Benefits of Gigabit
    Use the Gigabit Ethernet ports for quicker file sharing between other Gigabit-enabled devices like media servers, hard drives and computers.
  • Wireless-N technology
    Speed up your wireless network with a router that connects your computer, game consoles and other Wi-Fi devices at high transfer speed.
Linksys E2000 - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE
Routing Protocol
RIP, static IP routing
Remote Management Protocol
HTTP, HTTPS
128-bit encryption, NAT support, Stateful Packet Inspection (SPI), MAC address filtering, VPN passthrough, parental control, firmware upgradable, wall mountable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
20.2 cm x 16 cm x 3.4 cm
300 g
Microsoft Certification
Compatible with Windows 7
Microsoft Windows 7, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X 10.4.11 - 10.6.1
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
PPTP, L2TP, PPPoE
Routing Protocol
HTTP, HTTPS
Encryption Algorithm
128-bit WEP, 64-bit WEP, 40-bit WEP, WPA, WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, IC CS-03, FCC
Status Indicators
Port status, power
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x RJ-45
Aerial
Aerial
Internal
Antenna Qty
3
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
20.2 cm
16 cm
3.4 cm
300 g
Limited warranty - 1 year
10 - 85%
