Lenovo ThinkVision M15 15.6" 1920x1080 6ms USB-C LED Monitor
Quicklinx: GQWBWS00 Mfr#: 62CAUAT1WL
Diagonal Size: 15.6 in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: None
Interfaces: USB-C
Hurry, only 3 left in stock!
£195.42 ex VAT
£234.50 inc VAT
Make productivity portable with ThinkVision M15. Its stunning form factor is meticulously designed to expand and match the screen real estate of multiple kinds of laptop, this light and slim mobile monitor is perfect for multi-screen multitasking like spreadsheets in an airport lounge or sharing a presentation with a prospect in a restaurant.
Equipped with two identical USB Type-C ports, the monitor gives users indispensable power-pass-through capability. That means they can power both the monitor and the laptop with a single power adapter, plugged into one port with a USB Type-C cable connected to the computer from the other port. Or they can simply power M15 from the laptop using just one USB Type-C connection. With safety ever in ThinkVision's minds, the M15 mobile monitor also comes equipped with Low Blue Light technology, which protects users from eyestrain caused by certain frequencies of blue light. Simply turn it on with the press of a button.
  • Lighter. Slimmer. Winner
    M15 does the heavy lifting of your productivity in a surprisingly light package. Just 860g1 and measuring no more than 6 mm through its head, this considerately crafted mobile monitor doubles users' screen space with a 15.6-inch, In-Plane Switching panel, FHD display, the perfect resolution for a monitor of its size. With expanded screen real estate, work such as comparing detailed spreadsheets is made so much easier, multitasking is a breeze and colleagues or salespeople can mirror or extend their screen to give prospective clients a presentation on their own screen, face to face, even in public spaces. Thanks to M15's integrated, fold-out stand with height adjustment, the monitor will raise up to align with a laptop for the most seamless user experience.
  • Stay in charge with Power Pass Through
    M15 handles power with elegance and simplicity. Its true one-cable design solution means it can run off a single USB Type-C2 cable that delivers images, audio and data, as well as power, to the monitor from a connected laptop for supreme convenience on the road. But add to that its second, identical USB Type C2 port and its invaluable Power Pass Through function allows both the monitor and the laptop to be charged from a single USB Type-C2 power plug. On top of enjoying this convenient design for power, users can also connect flash disks, earphones or other compatible USB Type-C2 devices through the monitor's second USB Type-C2 port when it's not in use
  • XS size, XL UX
    Taking M15 on the road may mean more hours of operation. With that in mind, it's thoughtfully designed to care for users' eyes by protecting them from eye fatigue and strain caused by harmful, high-energy blue-wavelength light. This is done with TÜV Rheinland Low Blue Light certified technology that can be switched on in an instant and left on for as long as users choose. Thought has even been given to the unboxing experience, with newly designed, easy-opening packaging that takes just seconds to have the monitor in users' hands. To keep its already modest weight down, M15's protective sleeve is lightweight, modern and elegant. And it even mounts to the wall by a VESA 100 mm fixture for a more stable solution when users spend time in the office.
Lenovo ThinkVision M15 - LED monitor - Full HD (1080p) - 15.6" - Campus
LED-backlit LCD monitor - 15.6"
Energy Class
Class C
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.17925 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms (typical), 6 ms (fast)
Colour Support
16.7 million colours
Colour Gamut
45% NTSC
Input Connectors
2xUSB-C
Display Position Adjustments
Height, tilt
Voltage
DC 5 - 15 V
Raven black
36 cm x 1.63 cm x 23.55 cm
860 g
Manufacturer Selling Program
Lenovo Campus
Environmental Standards
ENERGY STAR Qualified
HDCP
Display Type
Energy Class
Class C
Diagonal Size
15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.17925 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
45% NTSC
Response Time
Backlight Technology
WLED
HDCP, 8-bit Colour Depth
Raven black
860 g
2 x USB-C
Mechanical
Height, tilt
Tilt Angle
0/+90
1 x USB-C cable - 1 m
HDCP
Lenovo Campus
Security Slot Type
Kensington security slot
Input Voltage
DC 5 - 15 V
7.5 kWh/1000h
Power Consumption (Typical)
8 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7, Windows 10
Shipping Weight
1.69 kg
Sustainability Information
ENERGY STAR Certified
10 - 80% (non-condensing)
Response Time: 6ms
Speakers: None
Interfaces: USB-C
Brand: Lenovo
