Lenovo ThinkVision E29w-20 29" 2560x1080 4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: GNB6WS00 Mfr#: 62CEGAT3UK
Diagonal Size: 29in
Max Resolution: 2560 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
40 In Stock
£150.76 ex VAT
£180.91 inc VAT
A pathbreaker for ultra-wide business monitors, the ThinkVision E29w-20 brings together brilliant technology and modern design in an immersive display like no other. Its ultra-wide, 29-inch In-Plane Switching panel offers more screen space and a wide field of view, so content creators and multitaskers can see wider and do more. The 2560 x 1080 pixel resolution delivers precise display quality so creators can catch every detail. Featuring a 21:9 aspect ratio, multitaskers have no trouble working on multiple windows simultaneously. Natural Low Blue Light technology built into the E29w-20 ensures eye protection without sacrificing color accuracy. An ergonomic stand, offering tilt, swivel, and lift functions, makes it easy to adjust and comfortable to use. A comprehensive multimedia experience is assured with two in-built 3W modular speakers that deliver crisp and clear sound to watch a video or jump onto a virtual conference.
  • Captivating Ultrawide Panel
    Featuring a 29-inch ultra-wide display with a 2560 x 1080 pixel resolution, the E29w-20 delivers an immersive viewing experience and outstanding image clarity that's sure to keep content creators inspired and productive. Its 21:9 aspect ratio has +33% more pixels than 16:9 monitors, letting users see more information at any given moment. Adjust the aspect ratio of any application to facilitate smooth multitasking and gain easy access to more options on design tools without needing to scroll or minimize windows. Around the display, 3-side NearEdgless bezels look narrow and sleek, adding a modern feel to the office.
  • Uninhibited Display Performance
    The ThinkVision E29w-20 doesn't just look good; its In-Plane Switching panel ensures unrestricted viewing angles, up to 178°, and an impressive contrast ratio of 1000:1 for accurate color performance. An outlier in the 29-inch segment, it offers Natural Low Blue Light technology to reduce eye strain without distorting the color output. Covering 99% of the sRGB color gamut, the E29w-20 can display a wide range of colors that is more than sufficient for business tasks or light photo editing. AMD FreeSync technology1 and a 90 Hz refresh rate virtually eliminate screen tearing and stuttering, making fast-paced gaming and video streaming on the E29w-20 a silky smooth experience.
    Taking the monitor experience beyond only video, 2 x 3W integrated modular speakers ensure loud and clear audio for virtual conferencing, watching videos, and more. Built on a supremely flexible stand, with lift, tilt, and swivel functions, the monitor can be adjusted to match any user's requirements, no matter where they are working. Its DP 1.2 and HDMI 1.4 multimedia ports are compatible with most devices, transferring high-quality video and audio signals. For added convenience, a cable management clip reduces desk clutter and 100mm VESA mount compatibility enables easy deployment.
Lenovo ThinkVision E29w-20 - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class D
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
13 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080
Pixel Pitch
0.2628 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
68.84 cm x 22 cm x 50.81 cm
6.6 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold
CCC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, EU RoHS 2002/95/EC, TUV Hardware Low Blue Light Certification
3-year warranty
Display Type
Energy Class
Class D
40 kWh
Diagonal Size
29"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080
Pixel Pitch
0.2628 mm
Pixel Per Inch
96
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
90 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Eyesafe technology, 3-side NearEdgeless, 8-bit + Hi-FRC Colour Depth, 99% sRGB colour gamut
Raven black
68.84 cm x 22 cm x 50.81 cm - with stand
6.6 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI , DisplayPort 1.2 , Audio line-out
Mechanical
Tilt Angle
-5/+22
Swivel Angle
360
Height Adjustment
155 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
13 W
15 kWh/1000h
Power Consumption (Typical)
36 Watt
Power Consumption (Max)
45 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Lenovo Display Control Center, Lenovo ThinkColour
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand (lowest position) - width: 68.84 cm - depth: 22 cm - height: 33.11 cm - weight: 6.6 kg , With stand (highest position) - width: 68.84 cm - depth: 22 cm - height: 50.81 cm - weight: 6.6 kg , Without stand - width: 68.84 cm - depth: 47.5 cm - height: 32 cm - weight: 4.4 kg
Shipping Width
39.5 cm
Shipping Depth
79.6 cm
Shipping Height
15.5 cm
Shipping Weight
8.5 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 29in
Response Time: 4ms
Interfaces: HDMI
Brand: Lenovo
