Lenovo High Efficiency Power supply. 80 PLUS Platinum. AC 120/230 V - 550 Watt - for System x3650 M5 5462 (550 Watt).
- Lenovo High Efficiency - power supply - hot-plug / redundant - 550 Watt
- Power supply - hot-plug / redundant - plug-in module
- 80 PLUS Certification
- 80 PLUS Platinum
- Input Voltage
- AC 120/230 V
- Power Capacity
- 550 Watt
- 1-year warranty
- Designed For
- System x3650 M5 5462 (550 Watt)
- Input Voltage
- AC 120/230 V
- Input Voltage Range
- AC 100 - 127 / 200 - 240 V
- Frequency Required
- 50/60 Hz
- Power Capacity
- 550 Watt
- 80 PLUS Platinum
- Limited warranty - 1 year
- Designed For
- Lenovo System x3650 M5 5462 (550 Watt)
