LaCie 3TB d2 Quadra v3 7200RPM FW800/USB2/ESATA-300
Quicklinx: 7KG6WS00 Mfr#: LAC301549EK
Fully loaded with all the best interfaces - eSATA 3Gbits, FireWire 800, FireWire 400 and USB 2.0 - this all-in-one professional hard disk offers universal connectivity for PC and Mac users. For easy setup, the LaCie Setup Assistant helps format according to your needs. The unique, fanless aluminum heat sink design with 60 % more surface area for heat dissipation keeps it quiet and safe. With the LaCie Shortcut Button, easily launch any application in one push. Perfect for digital content creation, audio / video editing, DVD authoring, and web animation, etc., the d2 Quadra can handle multiple demanding professional tasks. It can be daisy-chained via FireWire or connected to your DV camera and is even bootable in FireWire for Mac and in eSATA for Mac / PC.
LaCie d2 Quadra Hard Disk - hard drive - 3 TB - FireWire 800 / USB 3.0 / eSATA-300
Hard drive - external (desktop)
3 TB
Data Transfer Rate
800Mbps(FireWire800)/5Gbps(USB 3.0)/3Gbps(eSATA)
Spindle Speed
7200 rpm
Power Source
Included AC adapter
18.3 cm x 16.8 cm x 6 cm
1.7 kg
Microsoft Certification
Compatible with Windows 7
3-year warranty
3 TB
18.3 cm
16.8 cm
6 cm
1.7 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
130 MB/s
Data Transfer Rate Details
USB 3.0: 130 MB/s , Serial ATA: 115 MB/s , FireWire 800: 85 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x eSATA-300 - 7 pin external Serial ATA , 2 x FireWire 800 - 9 pin FireWire 800 , 1 x USB 3.0 - 9 pin USB Type B
Power Source
Included AC adapter
Power adapter
Software Included
LaCie Setup Assistant, LaCie Desktop Manager, LaCie Backup Assistant
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6 or later, Apple MacOS X 10.5
Vertical stand
1 x USB 3.0 cable - USB Type A to B - external , 1 x eSATA cable - external , 1 x IEEE 1394 cable - FireWire 800 (9-to-9 pin) - external
Limited warranty - 3 years
