LaCie 1TB Rugged Mini USB 3.0 2.5" 5400RPM Hard Drive
Quicklinx: 7M6PWS00 Mfr#: LAC301558
Form Factor: 2.5
Capacity: 1TB
Interface: SuperSpeed USB
£63.98 ex VAT
£76.77 inc VAT
With its iconic design and secure form factor, the Rugged has been popular hard drive. With the Rugged Mini, LaCie had shrunk the Rugged, and added tons of more features, making it a solid investment for on-the-go data transport.
The LaCie Rugged Mini hard disk shares features with the popular Rugged hard disk, like shock resistance, drop resistance, and a rubber sleeve for added protection. But with the Rugged Mini, it's also rain-resistant, and pressure-resistant!
  • Small member of the Rugged family
  • Maximum reliability
  • The speed of USB 3.0
    With the Rugged Mini, you've got the speed of USB 3.0, and full backward compatibility with USB 2.0, meaning that you can use it on almost any computer.
LaCie Rugged Mini - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Shock resistant, pressure-proof, rugged, rain-resistant
Power Source
USB bus
8.6 cm x 13.5 cm x 1.9 cm
240 g
Microsoft Certification
Compatible with Windows 7
1 TB
USB 3.0
8.6 cm
13.5 cm
1.9 cm
240 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
LaCie Backup Assistant
Apple MacOS X 10.6, Microsoft Windows Vista / 2000 / XP, Apple MacOS X 10.5
Form Factor: 2.5
Capacity: 1TB
Brand: LaCie
