From enterprise to small and medium business, university computing labs to call centers, the Intel NUC is driving the models of computing in small spaces. The Intel NUC kit NUC5i5MYHE is powered by fast processor, providing an ideal combination of performance and reliability for usages where downtime isn't an option. Intel vPro technology helps you manage repairs remotely, reducing the time it takes to resolve hardware problems by 66 percent and software problems by 88 percent giving your customers the reliability and availability they require. The advanced capabilities of the processor, gives your customers performance to run video analytics to target messages to the right audience. And the triple display capability means your customers can deliver their messages across multiple screens. With 4K display support it's an ideal device for digital signage with video analytics, digital kiosk, intelligent vending, or PC replacement.
A serial port option to connect legacy embedded devices means that you can customize the Intel NUC for a wide-range of usages, including POS systems. A replaceable lid further extends options for customization, enabling third-party innovation and usage models with NFC and USB headers. Intel NUC NUC5i5MYHE has the option to install a 2.5" HDD or an M.2 SSD. The choice gives your customers options to store all their files locally or take advantage of the fast, power-efficient M.2 form factor which minimizes load times and improves reliability.
Superior processing and graphics
Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics. -
Stunningly small form factor
The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations. -
Advanced technology
The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
- Intel Next Unit of Computing Kit NUC5i5MYHE - mini PC - Core i5 5300U 2.3 GHz - vPro - 0 GB - no HDD
- PC barebone - mini PC - watchdog timer
- Platform Technology
- Intel vPro Platform
- Processor
- 1 x Intel Core i5 (5th Gen) 5300U / 2.3 GHz (, up to 2.9 GHz, (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology, Intel Virtualization Technology, Intel Turbo Boost Technology 2, Intel Wireless Display, Intel 64 Technology
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 5500
- Audio Output
- 7.1 channel surround - integrated
- Networking
- 1GbE
- OS Provided
- No operating system
- Silver with black top and diamond cut around the top
- 11.5 cm x 11.1 cm x 4.87 cm
- Limited warranty - replacement - 3 years
- PC barebone
- Product Form Factor
- Mini PC
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5300U
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 2.9 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
- Integrated
- Data Link Protocol
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x M.2 Card
- 4 x USB 3.0 (2 front, 2 rear) , 2 x Mini DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x SATA-600 (1 internal)
- Included Accessories
- VESA mounting kit
- Watchdog timer
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- EN55022, ICES-003, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, ACPI 3.0b, VCCI V-3, Directive 2002/96/EC, VCCI V-4, KN22, KN24, China RoHS, Directive 2011/65/UE, CAN/CSA-C22.2 No. 60950-1
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 11.5 cm
- 11.1 cm
- 4.87 cm
- 0 °C
- 50 °C
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.72 |
