The Next Unit of Computing Powered by a 3rd Generation Intel® Core™ i5 vPro™ Processor
A revolution in ultra-compact device design, the Next Unit of Computing packages a fully scalable, computing solution in the smallest possible form factor, complete with the Intel® Core™ i5 vPro™ processor. This new generation computing device provides a flexible, customizable engine to drive digital signage, kiosks, and intelligent computing for small spaces, or anywhere else you can imagine. The Next Unit of Computing also has triple display1 capabilities for multiple monitoring and display, along with Intel® vPro™ technology which lets your IT service provider remotely manage or repair your system. With that kind of power and size, you'll rethink what's possible. Because the only thing more amazing than Intel® technology is what you'll do with it.
- Power, capabilities, and performance in four square inches.
- Expand your market. Shrink your IT.
- Ultra compact. Ultra impact.
- The footprint is small. The potential is anything but.
- Reduce downtime. Increase effectiveness.
- Intel® Core™ i5 vPro Processor
- HDMI*
- Gigabit LAN
- 2 mini DisplayPorts
- 2 USB 2.0 ports and 1 USB 3.0 port
- 2 PCIe* mini slots
2x SO-DIMM slots
Requires two mini DisplayPort capable monitors.
Box Contents
- Intel NUC
- Power brick
- VESA Mounting bracket
- Intel Core i3 sticker
- Wifi antennae
- Please note you will need to purchase an A/C Power Cord
Ultra compact, ultra impact
A revolution in ultra-compact device design, Intel NUC packages a fully scalable, computing solution in the smallest possible form factor, complete with the Intel Core i5 processor. This computing to drive digital signage, kiosks, and intelligent computing for small spaces, or anywhere else you can imagine. -
Superior processing and graphics
Visibly smart graphics using the Intel Core i5-3427U processor equipped with the integrated Intel HD4000 graphics to provide amazing performance and visually stunning graphics across a triple display configuration.
- Intel Next Unit of Computing Kit DC53427HYE - UCFF - Core i5 3427U 1.8 GHz - vPro - 0 GB - no HDD
- PC barebone - ultra compact form factor - voltage monitoring, temperature sensor, automatic fan speed control
- Platform Technology
- Intel vPro Platform
- Processor
- 1 x Intel Core i5 (3rd Gen) 3427U / 1.8 GHz (, up to 2.8 GHz, (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology, Intel Execute Disable Bit, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel Turbo Boost Technology 2, Intel 64 Technology
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3 SDRAM
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 4000
- Audio Output
- 7.1 channel surround - integrated
- Networking
- 1GbE
- OS Provided
- No operating system
- 11.66 cm x 11.2 cm x 3.9 cm
- Limited warranty - 3 years
- PC barebone
- Product Form Factor
- Ultra compact form factor
Processor / Chipset
- CPU
- Intel Core i5 (3rd Gen) 3427U
- Clock Speed
- 1.8 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
- Chipset Type
- Mobile Intel QS77 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
- Unbuffered, dual channel memory architecture
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
- Integrated
- Data Link Protocol
- ACPI support
- Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x Mini PCIe - full-length , 1 (total) / 1 (free) x Mini PCIe - half-length
- 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 2 x Mini DisplayPort , 1 x USB 3.0
- Voltage monitoring, temperature sensor, automatic fan speed control
- Theft/Intrusion Protection
- EN55022, ICES-003, EN55024, CISPR 22, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-4, KN22, KN24, CAN/CSA-C22.2 No. 60950-1
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 11.66 cm
- 11.2 cm
- 3.9 cm
- 0 °C
- 55 °C
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
