Infocus IN118HDxc 1920x1080 3200 Lumens DLP 3D Projector
Quicklinx: BLL3WS00 Mfr#: IN118HDXC
Confidently beam your most important content with the high brightness and quality of the incredibly affordable IN110x series projectors.
These value-packed projectors are built to perform with HDMI input, high brightness, high contrast, and BrilliantColor technology. Plus, their compact design and light weight make them as easy to move around as they are to install.
  • Lowest total cost of ownership
    The IN110x series' lamps can last up to an amazing 10,000 hours. There aren't even any filters to replace. It's an unbeatable value.
  • 3D ready
    The IN110x series supports multiple forms of 3D - including Blu-Ray, 3D broadcasting, video games and PC connectivity.
  • Eco Blanking
    Instantly dim the screen to divert your audience's attention onto you with the Eco Blanking feature on the remote control. Activate this feature when the projector isn't being used and lower the lamp's power usage down to 30%. This saves energy and significantly extends the life of the lamp, which saves you money.
  • High brightness and high contrast
    The image quality of this projector will not disappoint. Up to 3200 lumens will give you bright, clear images with the lights on and the 15000:1 contrast ratio adds sharpness with darker blacks and whiter whites. Preset modes give you the best image quality on a beige wall, whiteboard, blackboard or other surface.
InFocus IN118HDxc - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3200 lumens
Contrast Ratio
15000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
203 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
29.2 cm x 22 cm x 12.1 cm
2.45 kg
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3200 lumens
Brightness (Reduced)
2900 lumens
Contrast Ratio
15000:1
Image Size
759 cm
Projection Distance
1.2 m - 10 m
Throw Ratio
1.4 - 1.7:1
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb type
203 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
6-segment colour wheel, BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, Eco Blank
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.22x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B (management) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), PIN code, security bar
UL, cUL, NOM, PCT, SABS, SASO, CB, CCC, PSB, FCC, IRAM, KCC, KC, CECP, EAC
29.2 cm
22 cm
12.1 cm
2.45 kg
Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
Sound Emission
32 dB
30 dB
BLL3 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
