Confidently beam your most important content with the high brightness and quality of the incredibly affordable IN112x projector.
It is built to perform with HDMI input, high brightness, high contrast, and BrilliantColor technology. Plus, its compact design makes it easy to move or install.
Save now and in the future
The ultra-low purchase price is just the beginning - the lamp is long-lasting and there are no filters to replace. -
Top-notch image technology
Even at this incredible low price this projector is made to perform for the long term. -
Easy to share or install
The InFocus IN112x projector's compact size and weight make it easy to move from room to room, but powerful enough to install.
- InFocus IN112x - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3200 lumens
- Contrast Ratio
- 15000:1
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 203 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- 29.2 cm x 22 cm x 12.1 cm
- 2.45 kg
- 2-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3200 lumens
- Brightness (Reduced)
- 2900 lumens
- Contrast Ratio
- 15000:1
- Image Size
- 759 cm
- Projection Distance
- 1 m - 10 m
- Throw Ratio
- 1.9 - 2.09:1
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91 kHz
- Bulb type
- 203 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
- 6-segment colour wheel, Closed Caption, BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, Eco Blank
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B (management) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code, security bar
- UL, cUL, NOM, PCT, SABS, SASO, CB, CCC, PSB, FCC, IRAM, KCC, KC, CECP, EAC
- Power Source
- AC
- 29.2 cm
- 22 cm
- 12.1 cm
- 2.45 kg
- Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 30 dB
